rode to angelsea damn never been so bored in my life
the few minutes alongside the rc8/749r on the freeway was well worth the trip though
Need non-learner bike + mates.
Patt, got my car running, took it for a spin.
stock turbo, Gtr cooler and stock airbox.
spool was f**king LOUD, it came on about 2.5k rpm and came on hard, a lot harder than my old 32 which would come on at 3.2k and not as hard and whisper quiet.
Sounds like a dump pipe gasket leak or failing turbo.
Stock air box with stock turbo is pretty quiet as you mentioned. Check for gasket leaks
Hook up a boost gauge and see if its not going past 10psi
f**k that just unlimited boost it until it dies
