Like every President before him, you deal with the situations that arise at the time. Sadly it's generally a thankless job plagued by backbenchers with little idea of the effort levels required.
No doubt about it. I'm sure I am only one of the many 'whingers' you have put up with over the years and I'm sure it's not easy.
However take a step back and look from our perspective. If we are not given the option to be listened and ideas genuinely considered then why should we strive for a position against the nay-sayers?
The clique I mentioned (whether you accept it or not) has moved on and many new faces are running the club now. Quite a contrast to the same people swapping seats for the past 5yrs. And in order to grow, the club needs to be more open which it is becoming.
I look forward to the new overlords :)
I'm a Westie brah soo nuna not so obvious lol
haha ye I thought you'd at least have a bit of an idea though :)
As per the Club Constitution, everyone has the option to write a formal letter addressed to the club. Same as all the questions raised @ AGMs & GMs are addressed as well. No-one does though. They just complain after decisions are made because they'd rather play a reactive role in their club rather than a proactive one
So I the cops towed my car to Spot on Panels and i had a look today, broken weather shield on passenger side, some graffiti on the pillars inside which i also found a marker in the boot, bits of bumps and scratches around the car, ignition barrel totally screwed, emptied glove box and the stuff in the boot and found my coin compartment totally ripped out and chucked on the floor....
Anyone know how much roughly premium goes up for insurance after claim?
as a rough guide, use the online caculator that most insurance comapnies have.
put in your details prior get quote
put in same details but tick one claim, see cost.
won;t be %100 accurate but close enough
Look like quite a bit of entertainment here last night.
Will need to organise some time of UFC Cage Fight for the Show N Shine
Pat v Ashrey
Moh V Dezz
Birds v Aaron
ill take on Leigh because were both bulkers
Lol. If you we're really open to club member opinions you would acknowledge informal comments made on the forum and encourage the person to submit their opinion through the best means to get it reviewed. Not play the power card and if that falls through say no one submits officially.
As you said, a proactive approach to handling opinions will get a much better result than a reactive one ;)
Dw Ash, I still love you, always love a good debate <3
Pat v Ashrey
Moh V Dezz
Birds v Aaron
Ill sit on the kent
I just had a new alarm installed. I can help but spend money on this car lol
    • Put a fuel pressure gauge on it. Replace the turbos. Probably completely separate issues.
    • What copper washer do you guys use on the bleeder bolts? The existing one I have I had no idea where to find it in a local store, I did buy some online but that are only 1mm thick whereas my old one is 2mm+ thick and when I put the new washer out and squeeze the top radiator hose I can hear a bit of air but not with the old one. Does this matter? The new one doesn't leak, but the inner diameter is a bit loose whereas the old one threads on the bolt.
    • Howdy all, after being out a few weeks ago on a spirited drive in my GTR I have 2 issues that oddly have appeared at the same time. Whilst accelerating quickly through the gears all of a sudden i’ve lost power at the top of third gear (below redline around 6000rpm) for no obvious reason.    From that point onwards the car has been running rich on idle, won’t really rev under load without a ton of black smoke and the odd backfire, and dying as a pull up to a set of lights unless I keep the revs up around 1500rpm. In addition when shutting down the car that same night (I was 10 minutes from home) I noticed one of the turbos was significantly noisy on wind down when shutting off the engine. After letting the car cool down overnight it starts up fine, although once it gets to temp the revs start to creep up and down, the exhaust is darker than it should be and it also sounds like it’s running rich (fat note) I’ve put a new set of plugs in it - no change, the old plugs all seemed OK with two of them being somewhat richer/fueled up than the other 3 with 1 being borderline. I’ve smoked tested the intake system via the front of the Turbos, found a split vacuum hose going to the factory boost gauge sender, which I have since replaced.  Also found another leak on the gasket coming off the rear turbo outlet, have also replaced this. After fixing both of these leaks - still have the running rich issue. I’ve also tried another pair of AFM’s - no change here After pulling off the front turbo intake pipes, there is obvious shaft play in the front turbo, which now hisses loudly on light revvs although I can’t see why this would make the car run funny even under idle. I’m curious to know why it’s running rich before I potentially replace/rebuild turbos. The car is completely stock <50,000kms  other than an exhaust. Oil and coolant are all clear. I haven’t bothered with coil packs as it looks like they won’t be the issue due to condition of the plugs. Any help appreciated as I cry myself to sleep!
    • No probs at all. I used to love trying to dig up obscure info for those in need where possible going back 20+ years on SAU.  I did have another look and couldn't come up with any closer match. I'm leaning towards those skirts in your first pic are custom fitments, cut down/extended or from another car entirely and modded to fit an R34 sedan. I would've thought someone in Japan had them and taken a photo at some stage over the last 2 decades but there's nothing. Someone out there must know surely.
