Bird's, depending on how long you want to wait (and if you can ignore no warranty) buy from the states, usually even with shipping it's cheaper than here
I got my 8' Rockford Fosgate sub for like $75 cheaper than anywhere here shipped from States... Just check eGay
Good idea but I did have a look online and landed would still be around $220 vs $238 in JB - might as well pay the extra and get warranty + not wait. Shame it's not like my Kayano shoes, which were $170 delivered and have only just hit Rebel Sport for $240 lol.
On the side, I'm amazed at how small amps are getting these days. Some of the Cadence micro amps, you could hide them anywhere in your car.
I got my audio stuff from jb on one of their 30% off car audio sales. Ceebs'd waiting too long for any good second hand deals to pop up so was like might as well, seemed decent value on sale.
Speaking of, after chucking in rears/sub & amp quite long ago, still haven't gotten around to installing the fronts in -___-
Edited by kaitoukid
There is a special way to prep and store them, 24hrs isn't long enough for the full benefits ;)
But that said, they will still taste awesome :D
darlek voice TAKE ME TO YOUR LEADER /dalek voice
I cannot recreate the fall off the bone as soon as you look at them of the originals.
Alpine Type X ;)
Nice sub the Type X
Im running a JL audio w6v2 with 1200wrms
Toby, I transferred my renewal payment last month, havent heard back. Show and Shine, next weekend and my sauvic card says im expired :(
In the mail Pat dont stress
Dan to the rescue haha!
    • Yeah, that's fine**. But the numbers you came up with are just wrong. Try it for yourself. Put in any voltage from the possible range and see what result you get. You get nonsense. ** When I say "fine", I mean, it's still shit. The very simple linear formula (slope & intercept) is shit for a sensor with a non-linear response. This is the curve, from your data above. Look at the CURVE! It's only really linear between about 30 and 90 °C. And if you used only that range to define a curve, it would be great. But you would go more and more wrong as you went to higher temps. And that is why the slope & intercept found when you use 50 and 150 as the end points is so bad halfway between those points. The real curve is a long way below the linear curve which just zips straight between the end points, like this one. You could probably use the same slope and a lower intercept, to move that straight line down, and spread the error out. But you would 5-10°C off in a lot of places. You'd need to say what temperature range you really wanted to be most right - say, 100 to 130, and plop the line closest to teh real curve in that region, which would make it quite wrong down at the lower temperatures. Let me just say that HPTuners are not being realistic in only allowing for a simple linear curve.
    • I feel I should re-iterate. The above picture is the only option available in the software and the blurb from HP Tuners I quoted earlier is the only way to add data to it and that's the description they offer as to how to figure it out. The only fields available is the blank box after (Input/ ) and the box right before = Output. Those are the only numbers that can be entered.
    • No, your formula is arse backwards. Mine is totally different to yours, and is the one I said was bang on at 50 and 150. I'll put your data into Excel (actually it already is, chart it and fit a linear fit to it, aiming to make it evenly wrong across the whole span. But not now. Other things to do first.
    • God damnit. The only option I actually have in the software is the one that is screenshotted. I am glad that I at least got it right... for those two points. Would it actually change anything if I chose/used 80C and 120C as the two points instead? My brain wants to imagine the formula put into HPtuners would be the same equation, otherwise none of this makes sense to me, unless: 1) The formula you put into VCM Scanner/HPTuners is always linear 2) The two points/input pairs are only arbitrary to choose (as the documentation implies) IF the actual scaling of the sensor is linear. then 3) If the scaling is not linear, the two points you choose matter a great deal, because the formula will draw a line between those two points only.
    • Nah, that is hella wrong. If I do a simple linear between 150°C (0.407v) and 50°C (2.98v) I get the formula Temperature = -38.8651*voltage + 165.8181 It is perfectly correct at 50 and 150, but it is as much as 20° out in the region of 110°C, because the actual data is significantly non-linear there. It is no more than 4° out down at the lowest temperatures, but is is seriously shit almost everywhere. I cannot believe that the instruction is to do a 2 point linear fit. I would say the method I used previously would have to be better.
