stock evo is like hot Amish girl,
even if there was one, why would you want it?
this is my fourth (and final) year at TAFE. Adv Diploma. I'll die before I go back...
however, work pays me to go, pays for the course and even payed kms to drive from edithvale to Heidelberg for a 1 week block every month. so can't really complain. problem with employer-funded courses is Workplace Assessments yayyy. took me 8 months to compile, fill-in and submit a document providing evidence and explanations to most of my work tasks for the last 4 years. everyone loves paperwork that has to be hand written. uni kids have the luxury of computers while TAFE barely trust our own handwriting lol. I never even got my pen licence in grade 4. why am I still talking...
f**k your clumping ravioli, San Remo...and f**k your panchetta-less tomato/pancetta sauce, Latina.
Unrelated: chewy dragees
I tried Coles brand ravioli last week cause it was half the price of the San remo stuff.
started boiling the water
put the pasta in
watch water change colour as the pasta bursts open
drain pasta of water and floating meat chunks
Bon appetite
:P was more poking fun at 99% of evos being modified.
but yes, there isn't enough love for pulsars round here. would liked to have made it to airport runs and earn some brownie points. oh well might have to do a 1/4 mile
Buy the engine and gearbox from my Mrs VRZ
Now
I got into my car last night after work, it was hot inside... even in a white car.
I glanced over at a workmate getting into his black z4, shorts, and he screamed and jumped back out of the car. dat leather seat burn.
Bahaha.
    • Starter motors used to use the weight of metal (magnets) to provide torque. Now they use (more) current instead. This. It's completely normal.
    • So thing that had me stumped, but I think is OK....is that when it was up in the air, in neutral I had it running to bleed to coolant while I put the wheels back on. I noticed the rears were turning (slowly) which I'd never seen before 20250928_163512.mp4     Because there had been an issue with clutch slip due to pedal adjustment on the dyno, I assumed there was still and issue so spent some quality time upside down under the dash adjusting the pedal....but no matter what I did the wheels still turned in neutral. Even disconnected the master cylinder to pedal rod and same. In despair, I even removed the clutch slave so there was no chance of any preload causing it.....still happened. So either: 1. Something is not right in the bellhousing, or 2. Its a thing sometimes with cold, thick gearbox oil Internet says it might be 2, I hope so!
    • OK, few more things sorted and it is ready for a shakedown on 10-Oct, with one weird thing. Changed the run in oil and filter for the good stuff. 8l came out, about 8.5 went in with filter so that looks all good. Changed the starter (again), this time for a brand new one, works good. Interesting that the Taaaarks one is shorter than factory but spins harder, I guess electronics have moved on a little in the last 30 years. Will be nice to have a bit of extra space under there. Put the timing cover back on, and noted where the cam gears were set as a record.  Will need to double check the timing but it is pretty close. Also put the coil pack cover and intake snorkel back on. Exhaust Inlet Changed the water out for coolant, bled up nicely. Removed the rear brake pads (well worn factory sumitomo ones!), gave the hardware a good clean and reassembled. I've put bendix XP on the back again because the price is excellent at $150 a set and they worked well on the V37. Front pads have plenty so no issue there
    • Mine is all -12, I’m running a dry sump in a billet block though
