Took the day off work and I'm sitting here patiently waiting for The Thread Doctor to arrive.
Removing a snapped dump bolt from my turbo rear housing, and 3 exhaust mani studs from my block.
What are you guys up to today?
I'm at southern grampians volunteering by setting and catching bandicoots for research O_o
Dat corporate volunteering
lol no worse?
you're in for a suprise lol
its not even so much economy.
major PITA having to fill up all the time because of the small child sized tank..
that and the turning circle lol.
the only two faults i have with the car...
replacing the o2 over the weekend to see if it makes it a little better as the o2 looked as if it was all over the place.
currently 250km to a tank.. stock. fun. no
that's ok... i'm not worried by the small tank... also 250k/40l is about the same as the skyline and that's not tuned... it should use less fuel but by a bees dick
Yeh, it seems ok, i just think I'm worrying too much and giving it abit too much boot. But when people are saying they normally get 320k out of a 7 tank..
Well...
37 litres i filled up to be exact..
got 252.3km lol
apparently tank size is 48 litres
which is bang on correct for 320km to a tank lol
i've literally calculated how paranoid about stupid shit I am haha
Watching Sopranos re-runs and job seeking.
And sorting out my farkin coilpack issues.
coilpacks +1 :(
need some new puppies in mine too. but mine have been dying for a while LOL.
coilpacks + major = happy days
hopefully.
*soon*
+ 1
Coilpacks letting go after 160,000K and hitting 19psi today
All my bolts came out fine only took a few mins
Me got my car tuned at Chequered tunning today
Fuel economy is for pussies.
+ 1
lol no worse?
Yup noticed the fuel economy in the Evo wasnt that great
And the turning circle is crap lol
What'd you make Toby?
Guy in an excel was driving behind me this afternoon, taking a photo of my car on his phone. Were u mirin me Dezz?
Coilpacks were failing so atm 265 rwkw on 19.5psi with a boost drop to 15.5psi at redline
If I sort out coilpacks and boost drop trent reckons should hit 300rwkw
    • Brooooo Please send ABS control unit schematic Please! R33 gts25t ABS (Its two plug ecu, black and white) wire colors possible? [email protected]
    • Don't even try to run it on the stock ECU if you're going to have the boost controller bring boost above ~10 psi. I've already told you that. If you use the Nistune ECU, you will need to CAREFULLY read the available documentation for Neo tuning, and read some threads on the Nistune forums, to discover the various things you have to do to prevent the ECU from going bananas when the boost is too high. The is a table associated with th boost sensor that must be modified to prevent it from shitting the bed. This is just one of the things that you will need to do to the tune in Nistune, because the Neo turbo ECU will be expecting to see a number of things (such as the TCS) that are not there, and you have to block the DTCs on those. It is totally not surprising to me that you are having the problems that you are, but the solutions to these problems have been known for >15 years. So just get it done.
    • Hi. Sry iam not a mechanic and iam not at the car atm so i dont know 100% but they told they measure those and even try to change those. AFM they have two. Coils are new a they have my old one too. Plugs too. ECU...we have 25 NEO stock and Nistune 25 NEO.   But i dont know if any one those could be the problem and why/if/what can cause this, Only thing they did not check is fuel...but that walbro 255 is new(like 1,5 years)... That fuel pressure gauge idk...but i let them know Any suggestions?   EDIT: how can they know if it is like you say he ECU pull power when it reaches a specific boost level that is too high? Tha car has boost controler
    • Can you clarify what you mean by boost cut, do you mean it misfires both when under load (driving) and when stationary and out of gear? Or does the ECU pull power when it reaches a specific boost level that is too high (boost control issue)? Does it occur at idle with no throttle? When you say "the ECU is OK", what ECU is it and why do you think it is OK? Have you used the NEO ECU, and if so do you have a MAP sensor attached? Same for the AFM, why do you think it is OK? Do you have any way to put a fuel pressure gauge on it (even just a mechanical one between the fuel filter and fuel rail)?
