http://www.gumtree.com.au/s-ad/south-yarra/keyboards-pianos/casio-px-120-electric-piano/1010510591
should i buy this?
been ages since i played, and this has 88keys and is fairly compact. reviews so far have been positive, and i've played its portable cousin, the cdp-200 a few times.
Should i? Or should i just save the kesh on something else.
I was massively disappointed when I went to mistys diner...
Gotta check out that big boy Bbq joint
What did you order? I don't think it's anything special, just very yank and a guaranteed fill up.
Anyone been that that American Buffet place that's opened on the corner of the 24 hour kmart in burwood?
Haven't yet. I will soon though!
Does it have oysters? Any all you can eat with oysters and I'm set
microwaving a glazed krispy kreme donut for 30s. hmmmmmmm yums
incorrect... krispy kreme donuts taste like man anus filled with jizz.
you woluld trust oysters from an all you can eat place?
you are game!
Oh, friend and I were planning a trip there. Only 800m from my work now.
Woot, rear hugger has shipped, just have to get a damn rwc so I can fit all the cool parts
you are game!
This. I don't trust food in general from an all you can eat place let alone seafood. If the buffet is <$60 a head I won't eat there.
Haven't had a problem so far :/
I normally eat about 2 dozen too. I lurve oysters
Only half a dozen or so for me, otherwise my tummy feels funny... Though it could be all the chili that I like to have with them :D
just buy them from a fishmonger and learn to open them yourself fool
taste 11ty times better and guaranteed fresh (alive) - not to mention cheaper
opening them isn't that hard, it takes practise to get really fast and some can give a little trouble to the uninitiated.
At the buller cruise a few years ago i took up around 6 dozen live ones and taught a few of the guys how to shuck them... i remember basti getting it pretty fast
Will need to remember to bring my own oysters and shuck them myself next time I get invited to an all you can eat
Don't always need to eat 5 star quality food brah.
Though this may also be why I eat Macca's several times a week
    • Starter motors used to use the weight of metal (magnets) to provide torque. Now they use (more) current instead. This. It's completely normal.
    • So thing that had me stumped, but I think is OK....is that when it was up in the air, in neutral I had it running to bleed to coolant while I put the wheels back on. I noticed the rears were turning (slowly) which I'd never seen before 20250928_163512.mp4     Because there had been an issue with clutch slip due to pedal adjustment on the dyno, I assumed there was still and issue so spent some quality time upside down under the dash adjusting the pedal....but no matter what I did the wheels still turned in neutral. Even disconnected the master cylinder to pedal rod and same. In despair, I even removed the clutch slave so there was no chance of any preload causing it.....still happened. So either: 1. Something is not right in the bellhousing, or 2. Its a thing sometimes with cold, thick gearbox oil Internet says it might be 2, I hope so!
    • OK, few more things sorted and it is ready for a shakedown on 10-Oct, with one weird thing. Changed the run in oil and filter for the good stuff. 8l came out, about 8.5 went in with filter so that looks all good. Changed the starter (again), this time for a brand new one, works good. Interesting that the Taaaarks one is shorter than factory but spins harder, I guess electronics have moved on a little in the last 30 years. Will be nice to have a bit of extra space under there. Put the timing cover back on, and noted where the cam gears were set as a record.  Will need to double check the timing but it is pretty close. Also put the coil pack cover and intake snorkel back on. Exhaust Inlet Changed the water out for coolant, bled up nicely. Removed the rear brake pads (well worn factory sumitomo ones!), gave the hardware a good clean and reassembled. I've put bendix XP on the back again because the price is excellent at $150 a set and they worked well on the V37. Front pads have plenty so no issue there
    • Mine is all -12, I’m running a dry sump in a billet block though
