Thanks for the spoiler jackass^
They both are side missions which I wasn't aware of either. So doesn't ruin the experience.
Finding trixie is one of the objectives. Traitor I'm not too sure what he means?
Re-do the mission and talk to the NPC's.
Sargent would have explained the traitor after the mission, from your first round.
Am I gonna need a different tow hook setup for my 33 for Sandown? If I do need a tow, my front bar is gonna get destroyed right?
I'm assuming its one of the Support Navara things with a towbar strap and a carbina on it?
Your car is already falling apart so, broken bumper will be least of your worries :P
3 weeks worth of WL read...that's a couple hours not getting back...
Haha. I'd personally wouldn't get my car washed there, detailed yes, the guy's real good, trained the guys at waxit. but not washed. Some of the things the guys do there bro, i'd be pissed off. Its a lot better than the magic hand ones though.
When they need to do a proper job, they'll do it (regular customer thats picky or whatnot), but most of the time its care free.
If you come in, i'll make sure its done properly :P
corner williamstown rd x francis street
how much discount..I live just up the rd.
yeh apparently 30% smaller, and the video quality, 1080p 60fps. even if it comes after, its well worth the wait..
will be good to use in fiji aswell, hopefully going parasailing if im not too fat for it LOL
when Fiji? where staying?
Just did Parasaliling in Boracay..scuba much more fun.
Who's good with computer viruses
I'm not shabby, which ones you want?
don't crash it easier..
only a few days, 30th Jan - Feb 3rd.. No Idea where staying, the missus has organised it with her dad, he owns a couple of apartments up there in some building.. mainly to go see her Grandma whos ill.. but yeh wanna do scuba, but cant imagine myself in a wetsuit.. beached... Also her cousins have access to some jet skis up there.. will do that too!
Toby when you upgrade?
LOL
Yeah all I'm gonna do is laugh...not at Hamish...but at someone buying a car with more power than they can handle and not treating it with respect, assuming that's what happened. Hopefully he wasn't insured so he can learn a nice long lesson from it...
How'd you find out about it Ham?
    • Brooooo Please send ABS control unit schematic Please! R33 gts25t ABS (Its two plug ecu, black and white) wire colors possible? [email protected]
    • Don't even try to run it on the stock ECU if you're going to have the boost controller bring boost above ~10 psi. I've already told you that. If you use the Nistune ECU, you will need to CAREFULLY read the available documentation for Neo tuning, and read some threads on the Nistune forums, to discover the various things you have to do to prevent the ECU from going bananas when the boost is too high. The is a table associated with th boost sensor that must be modified to prevent it from shitting the bed. This is just one of the things that you will need to do to the tune in Nistune, because the Neo turbo ECU will be expecting to see a number of things (such as the TCS) that are not there, and you have to block the DTCs on those. It is totally not surprising to me that you are having the problems that you are, but the solutions to these problems have been known for >15 years. So just get it done.
    • Hi. Sry iam not a mechanic and iam not at the car atm so i dont know 100% but they told they measure those and even try to change those. AFM they have two. Coils are new a they have my old one too. Plugs too. ECU...we have 25 NEO stock and Nistune 25 NEO.   But i dont know if any one those could be the problem and why/if/what can cause this, Only thing they did not check is fuel...but that walbro 255 is new(like 1,5 years)... That fuel pressure gauge idk...but i let them know Any suggestions?   EDIT: how can they know if it is like you say he ECU pull power when it reaches a specific boost level that is too high? Tha car has boost controler
    • Can you clarify what you mean by boost cut, do you mean it misfires both when under load (driving) and when stationary and out of gear? Or does the ECU pull power when it reaches a specific boost level that is too high (boost control issue)? Does it occur at idle with no throttle? When you say "the ECU is OK", what ECU is it and why do you think it is OK? Have you used the NEO ECU, and if so do you have a MAP sensor attached? Same for the AFM, why do you think it is OK? Do you have any way to put a fuel pressure gauge on it (even just a mechanical one between the fuel filter and fuel rail)?
