I wonder if ethical standards are looking into this at all...
surely they would have to at least take a peek seeing as there is clearly a lot of community angst about 1 particular member
VIC pol pulled down their Facebook post on their page. Everyone ended up complaining in that after they pulled the original page down lol
Well that's gay. Was an entertaining read.
So many uneducated people posting.
People discuss about a defect about DRL's
random posting about 'If he got a fine he deserved it/ if you didn't do anything wrong you wouldn't worry about it! / Glad he got a find and mr pettit is making the streets safer/ damn hoons!
I'll get you the number of where I got.mine (good hookup)
Please tell me DRLs does not stand for driving lights..
Drl stands for daytime running lights
ie BMW angel eyes or led strips etc attached from factory
I could only assume home done ones would technically be illegal if popo wanted to bother as they wouldn't have passed adrs etc for the Vy commos etc
You can have neons, the colors aren't allowed to be blue or red, and you are not allowed to see the globe(or the physical light source)
Hid's are not allowed because you are tampering with a ADR approved head light, and you are not allowed hid fogs, because to pass ADR they need to have jets to clean them
Hence not ADR approved fogs
    • Starter motors used to use the weight of metal (magnets) to provide torque. Now they use (more) current instead. This. It's completely normal.
    • So thing that had me stumped, but I think is OK....is that when it was up in the air, in neutral I had it running to bleed to coolant while I put the wheels back on. I noticed the rears were turning (slowly) which I'd never seen before 20250928_163512.mp4     Because there had been an issue with clutch slip due to pedal adjustment on the dyno, I assumed there was still and issue so spent some quality time upside down under the dash adjusting the pedal....but no matter what I did the wheels still turned in neutral. Even disconnected the master cylinder to pedal rod and same. In despair, I even removed the clutch slave so there was no chance of any preload causing it.....still happened. So either: 1. Something is not right in the bellhousing, or 2. Its a thing sometimes with cold, thick gearbox oil Internet says it might be 2, I hope so!
    • OK, few more things sorted and it is ready for a shakedown on 10-Oct, with one weird thing. Changed the run in oil and filter for the good stuff. 8l came out, about 8.5 went in with filter so that looks all good. Changed the starter (again), this time for a brand new one, works good. Interesting that the Taaaarks one is shorter than factory but spins harder, I guess electronics have moved on a little in the last 30 years. Will be nice to have a bit of extra space under there. Put the timing cover back on, and noted where the cam gears were set as a record.  Will need to double check the timing but it is pretty close. Also put the coil pack cover and intake snorkel back on. Exhaust Inlet Changed the water out for coolant, bled up nicely. Removed the rear brake pads (well worn factory sumitomo ones!), gave the hardware a good clean and reassembled. I've put bendix XP on the back again because the price is excellent at $150 a set and they worked well on the V37. Front pads have plenty so no issue there
    • Mine is all -12, I’m running a dry sump in a billet block though
