any progress undone by the unrivaled faggotry of the bintang singlet
Hahaha I'm glad someone said this, he apparently wears it just to piss me off. Him and 3 or 4 douchebags at my gym, any given time.
It'll make you more mad when I tell you I've never been to Bali / Thailand or wherever the f**k they're from
Then, where the f**k do you get the homo singlet?
bintang singlet....
worn by the worst class of bogan f**kwit's that are desperate for people to know they went to bali and stuck to the areas only populated by other australian tourists and ate nothing but western food.
94% of these wankers will have a sothern cross tatoo... FACT
f**k, woke up at 4am from an alarm going off in the house. Disoriented, thought it was alarm clock but too early for that. Then it turns off... no f**king idea what it was...maybe smoke alarm was playing up?
Talk about end of world :/ haha
Rest of night was spent thinking wtf was the noise...
If it was smoke alarm I was so not prepped in getting out of house. Wanted my sleep haha
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
    • It's not that straightforward. For example I have had this code because my ignitor/power transistor wires were unplugged. It knows something is wrong but has no idea what it means. If you want to actually diagnose this I recommend following the service manual flowchart for code 21. Ohm out the harness, coilpacks, inspect the ECU, etc. And again, it's entirely possible for there to be no problem at all but if you're running a different coilpack it'll trigger the code because it doesn't like what it sees.
    • If it (the code) wasn't still current, it should have gone away by itself by now. No, nothing it 10/10. But it is quite likely. Everything else to do with the ignition could still be responsible (which is wires and connectors). The car is an old piece of shit now, so all the wires and connectors are also old pieces of shit.
    • Lock me in mate, although I'm not sure if I'll be heading up from Goulburn or down from Sydney, either way, return will be back to Goulburn
