I know its a few pages back
But how is his surname actually spelt,
Pettet
Pettite
Pettit
Can we get a poll going on ? cause everyones doing it differently. Also has he got a wife? cause i know of a pettit somewhere in southeast. :P
Pettett if I remember correctly from the defect label, I'll look later.
Ive been knox a handful of times in my r34, never had any trouble... yet
I drive past there 5 times a week and have only had trouble once. But it does happen; just a numbers game and the wrong time of day.
my brothers now 340rwkw (on trents hub dyno at least..) car still cant pull on me, dat dere turbo lag vs supercharger
can we quit this faggotry about hub dyno's reading higher please? i'm soooo over it! they are better and more accurate... it's one dude in adelaide that bullshits his figures and happens to have a hub.
trent's dyno is callibrated correctly and runs the appropriate correction mode.
cars on trent's dyno make the same power as on a dyno dynamics in shoot 6 mode
my car was within 10kw of 2 different dyno dynamics rollers
Pettet
Pettite
Pettit
easy...
F A G G O T
easy...
F A G G O T
Hub dynos are better as you eliminate variables in the tuning (tyre pressure & slip at the wheels) makes it possible to repeat runs and have results the same. Good for fine tuning as you don't have unknown variables messing with each run.
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
