Damn now I want to eat some chicken rice.
Oh also on the topic of restaurants, night be heading to mamacita tomorrow. Anyone rate? :S
yeah went there a few weeks ago
food and drink were very good.
was on a work ebays expense account tho so that made it better ;)
Send me routine birds I are interested feeling like on a plateau at present
What are your lifting figures like? Wanna PM me with what you usually do at the gym, how often you go etc.? As detailed as possible.
Isn't there a poofy lifting thread already? If you don't lift in multiples of gearboxes, I don't want to read about it phags.
:P
They keep talking about Suppliments...
I can only assume that they'll make your gearbox seep from the rear welsh plug...
:P
GQ Patrol gearbox with transfer case? If you can lift one you're doing well lol
There's also a homos only Stagea section for people like you :P
oooh nice! haha work account? very jelly.
"what would you like this evening sir?"
-"well, to start off... 11ty tequila shots.... pls"
Was actually would you gents like a chefs selection?
Yes
Ok we will bring matching tequilas and some jugs of margaritas
Yes
this is how i eat at pretty much any decent restaurant i go to..
it's ALWAYS the best way to go
Congrats Tob!
When i was home gyming I was taking a mass gainer for a bit, and just ate lots of anything really I probably didn't gain that much muscle (mainly because I wasn't working out hard enough / often enough) but at least gained a bit of mass and newbie gains.
I always have a protein shake after gym but TRY to have it twice a day sometimes I forget though / don't get a chance.
The problem with me is that i think i need a gym buddy, used to have one until i changed gym. Find it harder to push myself further going solo.
Protein shake twice a day? Is this like everyday?
Aren't no body got money like that!
Yep I've got the BN chocolate :)
Birds made me do it
Currently trying Gold Standard- double rich chocolate. Not bad imo.
No secret recipe to it, though I do think I'm a good coach of technique and stepping up weight in a smart manner.
Can send you our workout, but there's a hundred ways to achieve the same thing.
Pm me? There might be hundred ways but I'm curious of the Bird's way. :)
    • So, version 4 intake is on its way I was looking at these a while ago but at around $200 or more it was a little pricey for something that might not work, but, I had it in my watch list, but, I got a message saying it was on special, and I had a code thingie to use, it eventually came in at $120 delivered, so BAM, BUY NOW.....LOL I'll need to have a look when it arrives but I feel it will "look" better than what I currently have, as it comes with a PCV fitting, so I will be able to get rid of the alloy pipe that goes to the throttle body with the PCV fitting  Well, that's what the voices in my head are telling me  Oh, and this happened today Yeap, it was a Trojan, and it was cheap, so I headed back to the hardware store and actually spent a little bit more on a heavy duty,  one that was actually recommended by a plumber mate, a Cyclone one with a fibreglass handle that is actually rated for clay The broken shovel will eventually be "modified" into a short handle shovel
    • When you pulled it off, there is no signs of blown head gasket? Is it possible you have some other issues going on? Possible cracked blocked? Or do you think it's straight up lifting the head? Did you check what the head was torqued to before pulling it down (To see if possibly they're stretching, or starting to break threads out etc)?
    • Seems like a decent result for a modded JZX110. They are bulky in comparison to the 100 and 90 models (which I'd prefer myself) but they are getting very few and far between here in JP these days. Thanks for the detailed review and the import process into the UK. I also have a car which I'm hoping to export from Japan at some stage so it's good to know if someone from the UK was interested in it. By the way the corrosion underneath is par for the course for cars which were located in/near the mountains or along the Japan sea coastline. They get huge amounts of snow every winter and the sodium chloride is used on the roads. Many cars have some kind of rubber like treatment underneath but they tend to limit it to the wheel arches underbody and fuel tank. Suspension arms and sub-frames will have similar corrosion to your JZX110 which is a common sight. See it all the time and car dealers here generally don't even mention it unless asked.
    • If the sound goes away when you clutch in, the 1.5/2 way diffs are just shit, and you are a normal person. The diff is likely "fine" but driving at anything under 30kmh is a violent horrible experience. It would be exaggerated with solid diff bushings and subframe bushings if you have those.
