LOL, how is the stang restoration going?
well I got it sand blasted last weekend..
so atm we are keeping zero external panels
no rust but horrific repairs in teh past, frame/chassis ok and panels are cheap $1500 will get me every one.
but year it very very ugly will post up some pics tomorrow when I have a little free time.
on the topic of owing kesh, i owe like ~20 (not paying interest, but that's another story) but don't give any f**ks really.. gives me something to work towards and a reason to rock up to work every morning :D still live at home too anyway #YOLO
I've got around 30 in CBA shares too which I plan to use for house when that time comes, still young (I think? 23? lol) nah but seriously house is on the list.. I know Pat and Nick have investment properties which is awesome props brahz
Never too young to buy property. Best to do it when you still living at home, that way you can support the repayment until you get a job promo/get married.
Do it now, I hear Alex has good deals on properties. $0 commission deals for us SAU brahs
Alex, are you based in the western subs? If this is true then i might need to contact you in the near future. ;)
Fuark... gotta get from Dandy to Bayswater by public transport to pick up the car from the roadworthy place tomorrow morning tho. FML.
Shouldn't be too bad should it ? but you'd probably cop the traffic.
Suppose it's better than having bad chassis.
yeah well when I bought it it had a bent chassis.. spent many 000's to get that fixed to find the body is rooted.
BTW I would like to thank VIP car inspections for the bang up job they did on inspecting this prior to my purchase, I still have the original report they did for the car and yeah...there a reason I now use stateroads
What you didn't mean to do there, I see it.
    • Brooooo Please send ABS control unit schematic Please! R33 gts25t ABS (Its two plug ecu, black and white) wire colors possible? [email protected]
    • Don't even try to run it on the stock ECU if you're going to have the boost controller bring boost above ~10 psi. I've already told you that. If you use the Nistune ECU, you will need to CAREFULLY read the available documentation for Neo tuning, and read some threads on the Nistune forums, to discover the various things you have to do to prevent the ECU from going bananas when the boost is too high. The is a table associated with th boost sensor that must be modified to prevent it from shitting the bed. This is just one of the things that you will need to do to the tune in Nistune, because the Neo turbo ECU will be expecting to see a number of things (such as the TCS) that are not there, and you have to block the DTCs on those. It is totally not surprising to me that you are having the problems that you are, but the solutions to these problems have been known for >15 years. So just get it done.
    • Hi. Sry iam not a mechanic and iam not at the car atm so i dont know 100% but they told they measure those and even try to change those. AFM they have two. Coils are new a they have my old one too. Plugs too. ECU...we have 25 NEO stock and Nistune 25 NEO.   But i dont know if any one those could be the problem and why/if/what can cause this, Only thing they did not check is fuel...but that walbro 255 is new(like 1,5 years)... That fuel pressure gauge idk...but i let them know Any suggestions?   EDIT: how can they know if it is like you say he ECU pull power when it reaches a specific boost level that is too high? Tha car has boost controler
    • Can you clarify what you mean by boost cut, do you mean it misfires both when under load (driving) and when stationary and out of gear? Or does the ECU pull power when it reaches a specific boost level that is too high (boost control issue)? Does it occur at idle with no throttle? When you say "the ECU is OK", what ECU is it and why do you think it is OK? Have you used the NEO ECU, and if so do you have a MAP sensor attached? Same for the AFM, why do you think it is OK? Do you have any way to put a fuel pressure gauge on it (even just a mechanical one between the fuel filter and fuel rail)?
