I copypasta'd it as a quote, it still has the quote bit in there but wouldn't show up :/
copypaste is shit with this new format... you cant edit them at all and have to have the WHOLE post (unless someone can advise otherwise?)
You can edit them and don't have to have the WHOLE post
Odium shall advise otherwise.
You might be getting hit with CSS/JS bugs from the updates... Change the theme, then change back... It should force a css / javascript refresh
