So the current "thing" is.
pick the diamond for the ring purchase it, and present that.
then she comes in to get the ring made.
that said ti was not what I did, I went with a el chepo ring for proposal, and explained she could pick out her perfect one afterwards...seems to have worked.
This is what I did... simple silver band from tiffany's for the proposal and then we picked one together.
sure beats her wearing the ring she didn't want and hating on you for the next half century!
Just take the one she's wearing. Try and fit it to one of your fingers. Which ever one its closest too, there's your reference
obvious amateure is obvious.... :P
for this to work she has to wear one on her wedding finger, which she wont... because she isn't married
different fingers have different sizes yo
Yo Ham, at Buller last year we were talking tequlias
what were some to try? hitting us USA so going to pick some up
from the airport the selection may be a bit limited... I'd say to go a Patron Anejo and a Herradura Reposardo.
how to get ring finger size of missus....... cut it off while she sleeps?
Download tiffany an co app has a ring sizer in it you just put it on the screen and slide the scale to the circles meet
Failing that ask her friend / family who will keep mouth shut
TOLL priority is f**ked up.
I kinda think they lost my item. Supposed to come on monday, and i was waiting, no doorbell. Found that they left the card. Called them to schedule redelivery to a newsagent, told to go to newsagent yesterday after 10am, it wasn't there. Now they don't know where the f**k my item is.
What can I do? Call ombudsman?
Call Toll and get them to follow it up with the newsagent and call you back once they've located your package... maybe your package is smaller than normal peoples package...
Why does everyone jump straight to ombudsman right away? :P
    • Hi. Sry iam not a mechanic and iam not at the car atm so i dont know 100% but they told they measure those and even try to change those. AFM they have two. Coils are new a they have my old one too. Plugs too. ECU...we have 25 NEO stock and Nistune 25 NEO.   But i dont know if any one those could be the problem and why/if/what can cause this, Only thing they did not check is fuel...but that walbro 255 is new(like 1,5 years)... That fuel pressure gauge idk...but i let them know Any suggestions?   EDIT: how can they know if it is like you say he ECU pull power when it reaches a specific boost level that is too high? Tha car has boost controler
    • Can you clarify what you mean by boost cut, do you mean it misfires both when under load (driving) and when stationary and out of gear? Or does the ECU pull power when it reaches a specific boost level that is too high (boost control issue)? Does it occur at idle with no throttle? When you say "the ECU is OK", what ECU is it and why do you think it is OK? Have you used the NEO ECU, and if so do you have a MAP sensor attached? Same for the AFM, why do you think it is OK? Do you have any way to put a fuel pressure gauge on it (even just a mechanical one between the fuel filter and fuel rail)?
    • Hi.. Just another problem. So maybe you can help. I(my mechanic) done swap from my RB20DE NEO to RB25DET NEO. Everything is OK but we have a boost cut. Coils/Plugs are ok...AFM is ok. ECU is ok. I have Walbro 255 but it "changed" sound few months ago(you can hear it ouside) you did not hear that when it was new(maybe faulty?) Sooo...what now? What can cause this boost cut? It is even when you standing still...
