Scott and his deflating my tyres to 27psi warm.
Squirming tyres felt like water haha even Richo drove it and thought something was f**ked. And yep, 27psi did that
Lol my first track day at sandown when it was wet found out later my tyres were 26psi
Yeah we used all your studs. Was still one short. Had to use a bolt :/
Fitted the apexi intercooler. So epic. No reo cutting, no front bar cutting. Mounting Brackets lined up with factory holes. Pipes slid into position with no f**king around.
Shame they stopped making intercooler kits.
However in the process had to lose my factory options. No more auto spoiler and lost a fog light :(
Good to hear! Now you can start winning races :D
Just got an offer for $1500 for the pink S14. might take it. Anyone else want a track use only S14 for moar than $1500? Needs a wheel bearing and manual conversion
My first question would of been - why is it pink
ex queen st car. nuff said. they had cut the numbers out to do some dodgy shit and they had this perfectly good pink car left behind. basically bought it to make a track car, but then it lived in the back of my garage for like 5 years cos of skyline, golf, 240z and a heap of other cars being more fun to do shit with. Now I need to get my garage space back and I need it gone.
Can't be regged... ever... cos it doesn't have a VIN, and it's pink because of some mohomolebos in Syd.
2 get da chix wet cuz
Same colour. even had similarly mohomo chrome wheels that I told em to keep. Mine's a Series 1 (one in the pic is is a series 2). Wouldn't be surprised if this was the car that they used the VIN numbers for. Goddamn dodgy f**ks.
Haha soon...
I hope there will be no surprises when Trent tunes it. Car is hunting pretty bad now. Might have to check over the injectors, turbo, intercooler install
but richo didn't crash it right?
    • That is way more science than even I would use. I just eyeball it, not even accounting for the non-verticality of the tape measure when held on the lip and the centre at the same time. +/- 2mm is good enough for the girls I go out with.
    • So, before putting them in I need to understand the stock ride height. This is how I measured it: First, check the diameter of the wheel's centre cap, it was 52mm. Then put a piece of masking tape approximately across the centre and measure 27mm (half) from at least 3 sides to get a reasonable idea of the centre of the wheel cap. Mark that with a horizontal line as one measuring point. Then, directly above the wheel on the guard, put another piece of masking tape in approximately the centre. Use a string line to find out the point on the guard above the centre of the wheel cap and mark that. Then it is simple, just a tape measure to check the distance from centre of the wheel to the centre of the guard. Final results where  LF: 381mm RF: 379mm LR: 401mm RR: 400mm Pretty even considering they are 120,000klm old factory springs, lets call that 380 front and 400 rear.
    • So....knowing that I have a problem with power steering temps on track and another Wakefield day booked in next Friday, I've done the obvious thing They are very reasonably priced at $1650, considering they are a big monotube shock, double height adjustable (don't have to change pre-load to change ride height), one way adjustable damping and standard sized and customisable springs if you want something other than what comes with them. They come with 9kg/mm front and 4.5kg/mm front and I went with that as a starting point because I'll add adjustable sway bars too https://justjap.com/products/bc-racing-coilover-kit-ds-ds-infiniti-q50-v37-14-current#description Unfortunately they didn't come with rear strut tops so I've re-used the factory ones which was a bit of a pain. Also, the adjuster for the rear shock will be an absolute nightmare to get at, and while there are extensions in the kit I can't see any way you can actually attach or use them
    • I also had 2 bulbs blow at once, years ago in the stagea. made for a fun drive home. The issue was the voltage regulator had failed in the alternator and it was giving 15+ volts. Really, I was lucky all that was fried were the headlight bulbs. So, I'd suggest you check the voltage across your battery terminals with the car running and warmed up. Yes, you will need a multimeter to do so, sorry.
    • Good work to think to check that, and thanks for coming back to post up the outcome.
