Scott and his deflating my tyres to 27psi warm.
Squirming tyres felt like water haha even Richo drove it and thought something was f**ked. And yep, 27psi did that
Lol my first track day at sandown when it was wet found out later my tyres were 26psi
Yeah we used all your studs. Was still one short. Had to use a bolt :/
Fitted the apexi intercooler. So epic. No reo cutting, no front bar cutting. Mounting Brackets lined up with factory holes. Pipes slid into position with no f**king around.
Shame they stopped making intercooler kits.
However in the process had to lose my factory options. No more auto spoiler and lost a fog light :(
Good to hear! Now you can start winning races :D
Just got an offer for $1500 for the pink S14. might take it. Anyone else want a track use only S14 for moar than $1500? Needs a wheel bearing and manual conversion
My first question would of been - why is it pink
ex queen st car. nuff said. they had cut the numbers out to do some dodgy shit and they had this perfectly good pink car left behind. basically bought it to make a track car, but then it lived in the back of my garage for like 5 years cos of skyline, golf, 240z and a heap of other cars being more fun to do shit with. Now I need to get my garage space back and I need it gone.
Can't be regged... ever... cos it doesn't have a VIN, and it's pink because of some mohomolebos in Syd.
2 get da chix wet cuz
Same colour. even had similarly mohomo chrome wheels that I told em to keep. Mine's a Series 1 (one in the pic is is a series 2). Wouldn't be surprised if this was the car that they used the VIN numbers for. Goddamn dodgy f**ks.
Haha soon...
I hope there will be no surprises when Trent tunes it. Car is hunting pretty bad now. Might have to check over the injectors, turbo, intercooler install
but richo didn't crash it right?
    • Dear folks My family members have 4 different cars : Triton 2015 and Corolla 2011 and Mazda3 2012 and Hyundai Elantra 2014 Looking to buy engine oil funnel spill free What I found are are below  https://www.amazon.com/gp/aw/d/B0BBTTJNKX?ref=ppx_pt2_mob_b_prod_image&th=1 https://www.ebay.com.au/itm/145553221359?srsltid=AfmBOoqYBU6Ptw0LU_bAp_k67U3qkF97HHvePkA7iHZw8vUmiwoIRaRr https://www.amazon.com/gp/product/B09X23TCS5?th=1 Is there a funnel with attachment that fits most cars ? Don't mind to spend for a decent quality  Thx
    • Stock ECU (or more accurately stock tune) absolutely refuses to go over 10psi and behaves like you have seen. The Nistune is the same if it is the stock tune. If the Nistune chip has been tuned, the resulting tune could be literally anything for any combination of parts. The Nistune just makes the stock ECU Tunable.
    • So stock ECU does not like anything above 10 psi?  That Nistune one is just for "try" if it will be any different, I know it need to be tune for that. I know but YOU may know about these problem but i/we dont. They few little Skylines here let alone people who know anything about tham so that is why iam asking here
    • So now we have a radiator with no attachments whatsoever. It lifts up with a particularly tight spot between the drivers side air box mount and the lower radiator outlet, but if you've got this far you will sort that too. This is the lower mounts with the rad out so you can see where the rubber bushes go, it is a straight shot upwards Done! Assembly is the reverse of disassembly, with blood less likely to be shed.
    • Right, onto the second last trick. The Air Con condenser is mounted to the front of the radiator and stays in the car when the radiator is removed. There are 2x 10mm headed self tappers holding the top of the condenser to the radiator, remove those The bottom of the condenser is attached to the radiator with clips. You need to lift the condenser out of those clips and clear (up, then forward). f**ked if  could work out how to do that last bit with the front bumper on. I hope you can, and you share the trick.  Bumper removal probably deserves its own thread one day once I've recovered the will to live, but basically you need to remove the wheels, front inner guard liners (clips and 10mm headed bolts), the self tapper between the guard and the bumper at the rearmost point of the bumper (same as an R32 that bit), any remaining clips at the top/front of the grill, an absolute bastard design with a plate that holds the top of the bumper above the headlight each side (only 1 bolt which is tricky to get to, but the plate catches 2 places on the bumper and must be removed....carefully!) and push clips between the bumper and guard under the headlight. If you've done all that you will be faced with wiring for the fog lights on both sides and in ADM Q50 RS at least, 4 nasty tight plugs on the driver's side for the ADAS stuff. So, the clips at the bottom look like this on drivers side (looking from the front) And on the passenger side (also from the front), you can see this one is already out Clearance on both of these are super tight; the condenser needs to move up but the upper rad support mount prevents that, and the radiator can't move down far because it is (rubber) mounted. Once you achieve the impossible and drop the condenser off those mounts so it does not stop the rad moving, you are good to go
