on our way to heathcote yesterday notice ~100 cops at the truck stop on the freeway along with people and cameras awaiting something, pulled over on the side to see what's up. nek minit 3 helicopters show up, minute after ~150 bikies arrive from sydney escorted by more cops.
crazy shit. some mint looking harleys there i want one now.
She tried to blame it on me for parking where the Body Corporate doesn't like people to park... and then started screaming at me about Karma because I didn't apologise and accept blame for her reversing into me.
I don't actually think your genetics make you a bad driver... but well, you did spin your car right in front of me on turn two at Sandown... ifyouknowwhatimean...
I've got a LHS door at home in perfect condition. If you need one. Going cheap cheap.
Do you have intercooler pressure tester?
That would be called PVC pipe, bass fitting and air compressor. Bucket of soapy water.
Hook up the air compressor to the intercooler and block the other end, cover the core in soapy water and look for bubbles!
Yeah one of those. Got to drop off car to Trent at 2pm today and want to check for any leaks :(
perfect run tell me nismo r33 cluster is unavailable and they dont know when they will be getting any.
nengun tell me they spoke to nismo directly and dont know when this part will be made again..
RHDjapan havent responded =/
anyone know of any companys which may have this in stock?
are you 100% it was them?
revenge time
Can't prove it was them, but they are the only people who have had beef with us. I believe they have been evicted because we have put in several complaints along with other neighbors about them disrupting us, so I think they have a couple of months before they are kicked out. I guess that gives to licence to damage our property even more. Pretty immature from a couple in their 30s. I'm tempted to let their tyres down too, but someone has to be the big man.
    • So, version 4 intake is on its way I was looking at these a while ago but at around $200 or more it was a little pricey for something that might not work, but, I had it in my watch list, but, I got a message saying it was on special, and I had a code thingie to use, it eventually came in at $120 delivered, so BAM, BUY NOW.....LOL I'll need to have a look when it arrives but I feel it will "look" better than what I currently have, as it comes with a PCV fitting, so I will be able to get rid of the alloy pipe that goes to the throttle body with the PCV fitting  Well, that's what the voices in my head are telling me  Oh, and this happened today Yeap, it was a Trojan, and it was cheap, so I headed back to the hardware store and actually spent a little bit more on a heavy duty,  one that was actually recommended by a plumber mate, a Cyclone one with a fibreglass handle that is actually rated for clay The broken shovel will eventually be "modified" into a short handle shovel
    • When you pulled it off, there is no signs of blown head gasket? Is it possible you have some other issues going on? Possible cracked blocked? Or do you think it's straight up lifting the head? Did you check what the head was torqued to before pulling it down (To see if possibly they're stretching, or starting to break threads out etc)?
    • Seems like a decent result for a modded JZX110. They are bulky in comparison to the 100 and 90 models (which I'd prefer myself) but they are getting very few and far between here in JP these days. Thanks for the detailed review and the import process into the UK. I also have a car which I'm hoping to export from Japan at some stage so it's good to know if someone from the UK was interested in it. By the way the corrosion underneath is par for the course for cars which were located in/near the mountains or along the Japan sea coastline. They get huge amounts of snow every winter and the sodium chloride is used on the roads. Many cars have some kind of rubber like treatment underneath but they tend to limit it to the wheel arches underbody and fuel tank. Suspension arms and sub-frames will have similar corrosion to your JZX110 which is a common sight. See it all the time and car dealers here generally don't even mention it unless asked.
    • If the sound goes away when you clutch in, the 1.5/2 way diffs are just shit, and you are a normal person. The diff is likely "fine" but driving at anything under 30kmh is a violent horrible experience. It would be exaggerated with solid diff bushings and subframe bushings if you have those.
