lol not gonna get into this again.. but a certain supra made 430 somewhere and 348 at chasers dyno the other week, i beat it :D
all dynos are different, who cares it just means you go to the same place when you get work done to see the difference on power curve.
I can have up to 3 tunes on mine, So good for swapping from e85 to 98 and a valet tune :D
has nothing to do with hub vs roller... that is a dyno setup issue. you can do the same with roller.
I tend to change peoples ringtones to the Saxophone tone (if you haven't heard it, try it out LOOL) then lock the min volume to 15(which is max) and watch them rage :P
sax tone is BAD.... but probaly less annoying than "are you there? are you there? are you there? are you there?"
ahahaha yes agreed on both :P
All the dyno shit talk will stop when we all get on the rollers at RTR right? Same dyno, same conditions. :)
Now, who hasn't paid yet? Aaron isn't selling it too hard and I don't want it cancelled. Get on board guys...
Speaking of McFlurries, what flavours/toppings are they selling these days?
Feel like an ice cream but not going for a drive if they're still selling the shit ones they replaced the originals with
Try their tofee and caramel shake! Shits great
Still have oreo, but they put chocolate topping on as well
Pretty good
    • I can see between the water jacket and cyl 3 there wasn't a hard line of combustion gas. It certainly appears that the issue is coming from there. Yes, checked the tension. All at 100ft lbs where I set them 5 years ago. These blocks can crack but generally when they have been over bored. Mine is only 0.5mm oversize at 89.5mm. They break between cylinders around the 91mm mark. No sign of that with mine. My gut feeling is the head gasket lifted a while back when the studs stretched and i bandaided it by retorquing the studs. It's finally let go.
    • My Nismo 1.5 churps a bit on reverse turns when cold, but besides that feels like a stock diff.
    • Yes, but, I paid cash and I'm pretty sure the receipt was in the bin 10 minutes after I got home Note to self, keep all receipts
    • Bunnings would have just handed you your money back on that one!
    • So, version 4 intake is on its way I was looking at these a while ago but at around $200 or more it was a little pricey for something that might not work, but, I had it in my watch list, but, I got a message saying it was on special, and I had a code thingie to use, it eventually came in at $120 delivered, so BAM, BUY NOW.....LOL I'll need to have a look when it arrives but I feel it will "look" better than what I currently have, as it comes with a PCV fitting, so I will be able to get rid of the alloy pipe that goes to the throttle body with the PCV fitting  Well, that's what the voices in my head are telling me  Oh, and this happened today Yeap, it was a Trojan, and it was cheap, so I headed back to the hardware store and actually spent a little bit more on a heavy duty,  one that was actually recommended by a plumber mate, a Cyclone one with a fibreglass handle that is actually rated for clay The broken shovel will eventually be "modified" into a short handle shovel
