yup...
coming from a 300 kw RWD car it's a strange feeling to be able to accelerate in the wet even a little bit lol
with the EVO I can pin it all the way to redline in every gear... crazy stuff
yup...
Dont know that feel brah.
Nah but my old GTR was a bit sketchy in the wet in first gear imo every other gear fine good fun trolling around in the wet
so dyno day showed that i was misfiring roundabout 4k?
tested it on the eastern, and indeed, it does hesitate around there, so.. coilpacks?
kynoch, does amayama do good prices on oem coilpacks for a det neo? or am i better off going splitfires?
oem's should be more or less the same prices as splitfires these days... i went oem when i replaced mine.
sigh 3am assignmenting - we meet again... might be time to break out the energy drank
changing coilpacks should be part of a basic service for skylines it seems :P
however, running E85 on distributor-style ignition coils doesnt seem to work out for many.
changing coils on 20 year old cars! THE SHOCK!!!! :0
    • 3 Kids are starting to hit that ages. I wanted to get them something special to learn on, put down the screens and have some fun. 4Door 2001 R34DE Black Pearl GV1 Jap Import, AU 2nd owner. Pre Work done. Suspension - Wheels Pedders SportsRyder Coilovers   Wheels TSG Spokey Boi 18'x9.5"+15 Body JASI Aero 4 door Type R Full Kit LED Conversion - Parker, Blinkers, & Reverse Exhaust Hurricane Headers 100 CPI high flow cat 2.5" Piping Cannon muffler Internal Bride low max stradia ii - front seats  Bride RO seat base and Rails (R/H) Cube short shifter LED Conversion - Interior
    • Why are you so adamant on going M12? Why not follow Brad (GTSBoy) suggestion. You're talking moving from a 1/8" size, to a 1/2" effectively. 4 times bigger. Why skip the commonly available sizes in between? The bigger you go, the more likely you are to strip the threads out at a later date, as guaranteed, someone will put a huge spanner on the M12 and really tighten it up, and you're only in thin wall, so not a lot of threads to engage!
    • Hi. Yeah thanks. Car is already at tuners and it staying there to resolve "many" issues they do not like. So it is in a good hands. Getting a good tune on that Nistune ECU too so the car would be good. Just needs a little tune up and love.
    • Probably gonna remove manifold and turbo. I’m not sure if I can get M12 x 1.5 air tight. Could use high temp Loctite 246 or something similar, but I don’t know. Maybe it’s just best to remove everything again and weld an 1/8NPT on there instead.
    • Yeah, saw the ratios, not impressed. Would like the punch I have in the first gears now. With those ratios it won't be the same.  Also want the h pattern gearing, or at least a quiet gear set that don't need to come apart for service each year. Looks like the only "reasonable" way Is a 8hp70 transmission, but where is the fun in that🤷‍♂️
