yup...
coming from a 300 kw RWD car it's a strange feeling to be able to accelerate in the wet even a little bit lol
with the EVO I can pin it all the way to redline in every gear... crazy stuff
yup...
Dont know that feel brah.
Nah but my old GTR was a bit sketchy in the wet in first gear imo every other gear fine good fun trolling around in the wet
so dyno day showed that i was misfiring roundabout 4k?
tested it on the eastern, and indeed, it does hesitate around there, so.. coilpacks?
kynoch, does amayama do good prices on oem coilpacks for a det neo? or am i better off going splitfires?
oem's should be more or less the same prices as splitfires these days... i went oem when i replaced mine.
sigh 3am assignmenting - we meet again... might be time to break out the energy drank
changing coilpacks should be part of a basic service for skylines it seems :P
however, running E85 on distributor-style ignition coils doesnt seem to work out for many.
changing coils on 20 year old cars! THE SHOCK!!!! :0
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
    • It's not that straightforward. For example I have had this code because my ignitor/power transistor wires were unplugged. It knows something is wrong but has no idea what it means. If you want to actually diagnose this I recommend following the service manual flowchart for code 21. Ohm out the harness, coilpacks, inspect the ECU, etc. And again, it's entirely possible for there to be no problem at all but if you're running a different coilpack it'll trigger the code because it doesn't like what it sees.
    • If it (the code) wasn't still current, it should have gone away by itself by now. No, nothing it 10/10. But it is quite likely. Everything else to do with the ignition could still be responsible (which is wires and connectors). The car is an old piece of shit now, so all the wires and connectors are also old pieces of shit.
    • Lock me in mate, although I'm not sure if I'll be heading up from Goulburn or down from Sydney, either way, return will be back to Goulburn
