This woman looks like shit these days lol. Don't even wanna google image for a picture.
Oh and...Ralph Macchio aka The Karate Kid, is now as old ad Pat Morita (Mr Miyagi) was in the movie. Do you feel old now?
Pulsars are nice pity SSS isn't turbo. Did thought about Pulsar GTI-R, but you get more value for money from WRX over GTI-R.
GTiRs havent aged well and few havent been mistreated either. Though I do know someone who is selling a kinda unfinished project one cheap
http://forum.pulsar.org.au/showthread.php/98344-GTI-R-for-sale
or you could get the 300kw pulsar for $15k
http://forum.pulsar.org.au/showthread.php/89058-N14-Pulsar-SR20DET-(290KW-for-16k)
hasnt updated the post ina while but is E85 now
Can't see it, need to log in, cbf doing that.
How cheap is the GTI-R?
my friend broke up with his gf after 7 years just last week :/
At work I always ask the bride to be how long she's been with fiancé before getting married...varies anywhere from 3 to 10 years, but most are at least 5+ years. Crazy to think that a 7 year relationship could end and then what, assuming you start over again you gotta wait another few years to know if you wanna marry someone!
I reckon once I hit 25 I'll start to feel old :P
Bro I started feeling old after 21. When I started going to clubs and seeing people who looked like they were still in high school, I became old. But meh, I don't act my age anyway.
That's life...
Can clutch / gearbox brahs suss my thread in drivetrain section plz
What kind of rattle? When does it happen; clutch pedal pushed in or clutch pedal out? Or both?
There's a spring that holds the fork in place to prevent vertical movement, but the top of your pivot ball may also be damaged or broken.
    • That is way more science than even I would use. I just eyeball it, not even accounting for the non-verticality of the tape measure when held on the lip and the centre at the same time. +/- 2mm is good enough for the girls I go out with.
    • So, before putting them in I need to understand the stock ride height. This is how I measured it: First, check the diameter of the wheel's centre cap, it was 52mm. Then put a piece of masking tape approximately across the centre and measure 27mm (half) from at least 3 sides to get a reasonable idea of the centre of the wheel cap. Mark that with a horizontal line as one measuring point. Then, directly above the wheel on the guard, put another piece of masking tape in approximately the centre. Use a string line to find out the point on the guard above the centre of the wheel cap and mark that. Then it is simple, just a tape measure to check the distance from centre of the wheel to the centre of the guard. Final results where  LF: 381mm RF: 379mm LR: 401mm RR: 400mm Pretty even considering they are 120,000klm old factory springs, lets call that 380 front and 400 rear.
    • So....knowing that I have a problem with power steering temps on track and another Wakefield day booked in next Friday, I've done the obvious thing They are very reasonably priced at $1650, considering they are a big monotube shock, double height adjustable (don't have to change pre-load to change ride height), one way adjustable damping and standard sized and customisable springs if you want something other than what comes with them. They come with 9kg/mm front and 4.5kg/mm front and I went with that as a starting point because I'll add adjustable sway bars too https://justjap.com/products/bc-racing-coilover-kit-ds-ds-infiniti-q50-v37-14-current#description Unfortunately they didn't come with rear strut tops so I've re-used the factory ones which was a bit of a pain. Also, the adjuster for the rear shock will be an absolute nightmare to get at, and while there are extensions in the kit I can't see any way you can actually attach or use them
    • I also had 2 bulbs blow at once, years ago in the stagea. made for a fun drive home. The issue was the voltage regulator had failed in the alternator and it was giving 15+ volts. Really, I was lucky all that was fried were the headlight bulbs. So, I'd suggest you check the voltage across your battery terminals with the car running and warmed up. Yes, you will need a multimeter to do so, sorry.
    • Good work to think to check that, and thanks for coming back to post up the outcome.
