Yeah Alvin, bought Bel's old car. For me, bronze is a little bit hit and miss on silver. Took a pic in japan of a white 33R with bronze xd9 and looked epic though!
I kept trying to convince Brandon to sell me his LM GT4s but I think that'll never happen lol
Gunmetal XD9s do look nice on silver as well actually, there was a pic of one at Sandown on my
comp but the angle of the pic didnt display the wheels very well. I'll have a tinker on PS again to see what it'll look like.
Was originally quite firm on either TE37SL resprayed black or black LM GT4. But now the more I look at it, seems like
33Rs look better with some dish which both of these wheels tend not to have much of..
Yeah for the Te37 range of wheels need 19's to get the dish
I'm already going, it's the Liberty guys meeting there tonight. :P
I don't want none of this Hallam kebab bullshit. Lol. What time are you going, ill tag along then. Been having cravings
dude, it's been a week...
you preggers?
Matte gun metal grey....
Birds sounds like will miss you by a few hours getting in Wed morning.
Where she been?
Perth
And I will be absent for most of that week...consider me legally dead.
White Work XD9 on silver 33GTR work well? Had a little fiddle around on PS before cos I couldn't find any other silver 33 gtr with white xd9's.
My car looks 95% similar to this car. Excuse the front lip as I don't know how to use photoshop.
Panasports ftw Edited by bluejeans
Oh cheers for the comparison pic, see the bronze actually looks pretty good there :)
What kind of silver is it? If it's later model KR4, go bronze. If it's light-ish silver go dark gunmetal.
Panasports ftw
I want it back :( hell, I want a GTR again.
Agreed on TE37's being played out, although haven't seen people jumping on TTA edition (Tokyo Time Attack) could it be a sign that TE's aren't fashionable anymore?
So what's the update on the car and your plans?
I considered buying the car when it was up for sale
Bought -9s, mines front pipe, 3" test pipe, tomei ti catback, nismo twin plate and greddy profec b spec 2.
Still yet to buy pfc but its just a matter of time. The car came with Racepace cam gears so I'll
put them onto the new engine, which should arrive from Japan in about a months time.
Suspension, brakes, diffs etc will be attended to once money starts flowing again.
The car is actually a very nice example, went to see a lot of 33s before buying this one.
The others were all very tired and this one seemed to be the most genuine.
not TE37's TE37 SL's
TE37's will never look played out
Happy Friday everyone, any plans for the weekend?
I'm going to be replacing my Intake Manifold Gasket on Saturday... going to be so much fun :|
And Sunday going to be finishing off my frankenstein rear end with the freshly rebuilt R230 1.5way and GTR Drive Shafts... but still with GTST rear hubs... (hubs are a little smaller than the gtr ones, so going to have to join the gtst splines to the gtr shafts at the CV Joint, urgh)
    • Thanks for that, I'll check it all out. I can always do the brakes last anyway if its a problem.  The 16's are super cool, if they do fit I'll cruise around with them for a bit.
    • Well, that's kinda the point. The calipers might interfere with the inside of the barrels 16" rims are only about 14" inside the barrels, which is ~350mm, and 334mm rotors only leave about 8mm outboard for the caliper before you get to 350, And.... that;s not gunna be enough. If the rims have a larger ID than that, you might sneak it in. I'd be putting a measuring stick inside the wheel and eyeballing the extra required for the caliper outboard of the rotor before committing to bolting it all on.
    • OK, so again it has been a bit of a break but it was around researching what had been done since I didn't have access to Neil's records and not everything is obvious without pulling stuff apart. Happily the guy who assembled the engine had kept reasonable records, so we now know the final spec is: Bottom end: Standard block and crank Ross 86.5mm forgies, 9:1 compression Spool forged rods Standard main bolts Oil pump Spool billet gears in standard housing Aeroflow extended and baffled sump Head Freshly rebuilt standard head with new 80lb valve springs Mild porting/port match Head oil feed restrictor VCT disabled Tighe 805C reground cams (255 duration, 8.93 lift)  Adjustable cam gears on inlet/exhaust Standard head bolts, gasket not confirmed but assumed MLS External 555cc Nismo injectors Z32 AFM Bosch 023 Intank fuel pump Garret 2871 (factory housings and manifold) Hypertune FFP plenum with standard throttle   Time to book in a trip to Unigroup
    • I forgot about my shiny new plates!
    • Well, apparently they do fit, however this wont be a problem if not because the car will be stationary while i do the suspension work. I was just going to use the 16's to roll the old girl around if I needed to. I just need to get the E90 back on the road first. Yes! I'm a believer! 🙌 So, I contacted them because the site kinda sucks and I was really confused about what I'd need. They put together a package for me and because I was spraying all the seat surfaces and not doing spot fixes I decided not to send them a headrest to colour match, I just used their colour on file (and it was spot on).  I got some heavy duty cleaner, 1L of colour, a small bottle of dye hardener and a small bottle of the dye top coat. I also got a spray gun as I needed a larger nozzle than the gun I had and it was only $40 extra. From memory the total was ~$450 ish. Its not cheap but the result is awesome. They did add repair bits and pieces to the quote originally and the cost came down significantly when I said I didn't need any repair products. I did it over a weekend. The only issues I had were my own; I forgot to mix the hardener into the dye two coats but I had enough dye for 2 more coats with the hardener. I also just used up all the dye because why not and i rushed the last coat which gave me some runs. Thankfully the runs are under the headrests. The gun pattern wasn't great, very round and would have been better if it was a line. It made it a little tricky to get consistent coverage and I think having done the extra coats probably helped conceal any coverage issues. I contacted them again a few months later so I could get our X5 done (who the f**k thought white leather was a good idea for a family car?!) and they said they had some training to do in Sydney and I could get a reduced rate on the leather fix in the X5 if I let them demo their product on our car. So I agreed. When I took Bec in the E39 to pick it up, I showed them the job I'd done in my car and they were all (students included) really impressed. Note that they said the runs I created could be fixed easily at the time with a brush or an air compressor gun. So, now with the two cars done I can absolutely recommend Colourlock.  I'll take pics of both interiors and create a new thread.
