Yeah well being a mechanic I thought servicing would be easy, just parts I hear are expensive.
fair nuff. you've obviously chosen it because you like the look of em, so would be hard to swing you towards a different hatch. possibly of Japanese design/parts and good ol' Australian construction. I know some people with a few for sale. a white one stands out in particular. it's only $4500 drive away :P
Watanabe san's 930 only make 360rwhp from a n/a 3.8 6cyl... But bear in mind it also weighs just under a ton....
+ I'd say it's a totally different characteristic of a car.
Both good in their own ways.
Anybody know anything about the 4th Gen Golfs? I'm thinking about getting one as a daily.
had one.. shit.... dont bother
I wasn't saying 360rwhp isn't enough.... I was stating that the car is light as a feather and as such 360rwhp is pretty fkn quick.
equivalent of about 275rwkw per tonne... which is a FAST.... would bang /10
busy busy man working, wedding planning blah never ends man!
wait till you have a kid lol....
Had an STI owner compliment my car at the lights...I thought that was nice given no one seems to give a shit about R33 GTS-Ts anymore! He had 340hp at the wheels, fair mumbo for a Rex.
Yeah true that!
Aww that's nice. Your car is beautiful :)
~250kw, not too bad, needs more though.
i remember having a quick google, and on the subie forums i just kept seeing "any more you need to rebuild engine first" etc comments...
unlike le evo :P
    • Oh, also, forgot to add these photos I believe.
    • Thought i'd update on this. I was able to get in contact with Craig Lieberman and later on Darryl Alison (owner of Kaizo Industries). Darryl was able to help me verify that my car was in fact one of theirs and is helping me find more info on mine !
