Shingeki no Kyojin, havent watched ep 8 yet, i was surprised when
what i thought to be main character got eaten like that
dont show that spoiler alvin if you havent watched any of it yet.
i've already been spoiled by sankakucomplex, so not a big issue, and i dont quite mind spoilers anyway.
ill have to take you for a spin sometime... when its running again :(
baffled sumps for FWD SR20s dont exist, wew.
Accusump? might struggle for room in engine bay.
Dry sump? $$$
if you are building it anyway it's not a hastle to remove the stock sump and add some baffles/wings
Yeah maybe just make some custom baffles
If they don't exist on the sr20 what are the track guys using?
If you not chasing that much power maybe you might not need it if you don't want to spend the $$
Yeh they do. They just aren't great, even mine had tomei baffles in there.
I think it's different with the sideways engine lol
plenty of designs for RWD sumps, but anything bigger than normal for FWD hits the crossmember. found some custom stuff for the Sentra platforms, but it's all old old forum posts.
mk, hopefully something just be made up in the one I got
it's a little more than 2 straight bits, they need to be hinged at the top so when the g stop the oil comes back in and have stoppers to stop it .
so they are generally deeper so the metal not hit the crank..and there not space to go deeper on a FWD..
Carsales strikes again:
Dude: I saw your NISSAN PULSAR on carsales. still for sale?
Me: Yes it is, would you be interested in seeing the car this week?
Dude: Pulsar?
Me: Yes the white one.
Dude: Would u swap for a skyline r33?
She eats prawns, so that makes things a bit easier :)
this...
let the semen flow through you
FYP
Get it, because he's gay, and has the gay sex. :rolleyes:
(Yes, this Tuesday feels like Monday all over again, I'm bored )
Dry sump? $$$
Accusump can be installed anywhere, but you don't even have a boot right?
FYP
You wish I was gay little man, you believe you would have a chance.. You want some of this brown sugar don't u
    • Thank you, 100% the intent. New coils were due and the 17" sixers look/feel loads better than the stock wheels. The aero options are so spot on.   Thanks for the warm welcome, all!
    • 98 r34 gtt Been rocking my latest setup and car running like never before. Have put a good 200 miles on it since all the latest changes and additions. everything is dialed in and have been driving it a bunch.   However, all a sudden last weekend as soon as I pushed throttle passed 4k and the engine stumbles, (slow or fast acceleration) hesitates and doesn’t go above 4100 or so, like a misfire. Everything else seems fine. I had a “good” set of coil packs that I removed from car when I first got it when I changed them over to new coils. I swapped out current ones for those, but no change. I also changed the plugs, no change. Seems to rev over 4 when out of gear with no load just fine no “misfire”, but as soon as its in gear with a load of any kind, it “misfires” as soon as rpm drop back below 4 k it runs perfectly, smooth, starts, restarts and drives fine as long as I keep it below 4 k while in gear. All readings look fine, no CEL   Any idea as to what could all a sudden cause an issue when pushing rpms passed 4 k?
    • When you say your cams are 272/262 is that 272in and 262ex?
    • We're arguing semantics. I am saying 45 accel and a 55 deccel ramp are "2 ways". Even a 45 degree ramp and an 89 degree ramp is "2 ways", because it is literally... two ways. The cusco 55/30 ramp is a 2 way. It's two ways. I get it though - in normal nomenclature a "2 way" would be 45/45 or 55/55 or 60/60 i.e the same locking in both directions. And something like 45/65 would be considered "1.5 way". I would then say if we're getting into the nitty gritty then every locking diff is a "2 way" diff and we should not speak in 1.5, or 2 ways but ramp angles instead. Which ofc if one of those ramp angles is 90deg, that side is not doing any locking. :p So Nismo don't obviously sell 3 things. The fact of the matter that they only sell two items really goes to show that there's a 2 way and a "1,5 way" which is really a 1 way. I believe the actual lockup for the 'adjustability' of the GT pro is really just setting preload for when the ramps actually start locking up. It's not changing how much 'wayness' there is. It is (somehow) horribly explained. People just buy whatever diff and go "locks up good bruh" and that's what ends up on socials forever.
