My work phone is a Nokia C5 or something. Looks like the typical Nokia but has 3G etc. Battery life is worse than a taiwan smartphone, I first charged it all day, unplugged it and took it home. Wasnt touched for 2 days and then started beeping in the middle of the night cause it had low battery. Was on power save mode too.
Sent from my iphone with 4% battery left
Why not 50+
Because Hamish likes being Burned...
sent from my desk on work time while my company website is in meltdown and I should probably be fixing it but can't be stuffed because I'm too full of pad thai
I had to google "how to write a letter of resignation" while at work today. awks. probably not the first person to do that though
Bought a fast Class 10 64gb micro SD card.... ghost HD cam only takes up to 32gb apparently, but still works. Need a good 16-32gb SD card for DECa though, just incase it errors. Want to play around with different fps, reso's and lense angles.
    • So either way it is gearbox out and look what is wrong?  I know about the input shaft bearing. Even before swap/new clutch the it sounded exactly like this: So is that inout shaft bearing or the other was installed backwards?  And can some please tell me the part number for that input shaft bearing? The gearbox is small box from R34 N/A and number is FS5W71C. Thank you
    • I am yet to see anyone ever regret a quaife or helical. ...other than drifting/skidpan duties. I kind of want to upgrade my factory helical with a Quaife (but really it's not ultimately that different, and is a MASSIVE UNDERTAKING), that's how good the hype is about them, that I want to try them 'just to see'
    • D2 and Ksport are essentially the same thing and basically just generic Taiwanese manufacture. Better than ChinaBay crap, but... not top shelf. Öhlins have got to be some of the best dampers around, so likely to be a good option. It's going to get to the point though where I suggest you buy from Oz. We have at least 2x excellent options here. If I were you though, I'd be talking to KW about doing something for the R33. There's bugger all difference between that and the 32. In GTR land, anyway.
    • KW only offers a set for the R32 GTR. Popular options are D2 racing, Ksport or Öhlins. I have a D2 Racing coilover set, though I don't know for sure which one.
    • Well, the good news is you have more than one very good option for new coilovers in and around your country. Worth the drive over to KW to talk about GTR stuff.
