but you didnt do mining engineering. LOL wut? are they starting to hire again?
You are correct, i did not study mining engineering but what I do have are a very particular set of skills. Skills I have acquired over a very long career. Skills that make me a nightmare for people like you.
  • Like 1
Lol. the ability to own an r32 for ages? that has to be a skill.
Hey Tony , were you in jap restaurant in Hawthorn tonight?
Yes I was
I'm going to guess you were also somewhere in the restaurant
Haha well played
I loath Vietnam
had such a bad run there.
try somehting new
Boracay in the Philippine's is interesting.
Fiji always better than bali
or if you jsut looking to get drunk/stoned and chase chicks try:
http://en.wikipedia.org/wiki/Vang_Vieng
I've just gotten back from Fiji, was amazing.
Now I'm planning a trip to bali in August...
and going to book some flights to Fiji for next Feb... $238 return :| wut?!
Why would you get stoned in Vietnam... isn't any sorts of drugs in those countries a quick trip to the slammer for the rest of your life?
Bali isn't as good as Fiji. What'd you do in Fiji? I hope u did the jet ski safar
Family Holiday, first one in like a decade...
Stayed at the Koro Sun Resort near Savu Savu and relaxed the hell out of 1.5 weeks...
Didn't jet ski but snorkelled fished, kayaked, ate my body weight in food and cocktails each day...
Yeh woulda been quite hot there too. We stayed at the whyndam or however it's spelt. Was f**kn awesome
Snorkeled at beachcomber island after jet skiing an hour across the ocean to it lol.
Was expensive, but so much fun!
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
    • Legend. I ended up finding the facebook account of the owner of the first car i sent but sadly he deactivated the account. I think you’re right in saying it’s some sort of well done custom job. Really appreciate your help anyways.
    • Totally equivalent. Stock often goes from the comp cover because that's where the actuator is also installed and the factory needs 2" of hose to make the connection - and it comes as a pre-assembled unit. They totally have a boost reference from somewhere between the turbo and the throttle(s). Oh, jeez. Just do it in M12 then. We don't actually care that much. I would expect any such AN converter fitting to rely on an o-ring or some other seal onto a flat surface under the flange of the hex**, because bolt threads are no intended to provide a pressure seal. unlike..... pipe threads. **which also requires a suitably flat and smooth surface on the turbo's boss to provide the seal.
