Looks like owning a skyline in vic is only going to get harder and harder with dumbcu*ts like this driving around.
I bet Pettit is jizzing in his pants over this
Edited by eightsixboy
Placed order for new aircon compressor from Japan. ($1200)
Could have bought a second hand rb25 for that money...
Air con is for pussies
you could have bought performance parts with that $1200
or a basic wash and wax from final inspection
    • Oh, also, forgot to add these photos I believe.
    • Thought i'd update on this. I was able to get in contact with Craig Lieberman and later on Darryl Alison (owner of Kaizo Industries). Darryl was able to help me verify that my car was in fact one of theirs and is helping me find more info on mine !
