I can't see how fixing exhaust noise and smoke is going to cost 1k. assuming they dont change the standards.
a full epa is what? 80$.
noise test is 48.60
unless they're going to have their own in house testing stations and charge mad feez.
noise test is 48.60
they said in there, exhausts must not exceed 5db above factory testing.
that rules out every single aftermarket exhaust for anything pretty much.
