Get well Hamish...
In other news... Aaron, can you repossess one of these and make sure no-one else bids on it at auction? :P
http://smh.drive.com.au/new-car-reviews/mercedesbenz-a45-amg-first-drive-review-20130828-2sq7w.html
  • Like 1
I'm telling you all once.... Make sure you have private health insurance. I have seen probably 25+ doctors and specialists in the last 4 days, including the head of neurosurgery. In the public system I nearly died due to not being allowed to see a neuro consult, and was left in a cubicle for 6-7 hours with no real assistance until I had a fkn seizure.
This will easily be a $10k+ hospital trip for Medibank (thank Christ I have the best cover available - commercial cover through NAB)
This is the issue we shouldn't have. The public system should be just as good as private, I just pay for it at tax time instead ffs.
I could fix the public system overnight by banning companies asking for doctor's certificates for single sick days. Bloody stupid wasting thousands of hours of doctors time filling out stupid notes so employers feel better. Spend the money on Hospitals instead.
Rant over....
Rant over....
Or stop people from going to the doctors for antibiotics when they catch a common cold, or a myriad of hypochondria.
I wasn't even aware of bulk billing until a few years ago, consequently never bothered seeing a GP for any minor shit, cause I thought it would cost me money. Someone awares me of how Medicare works, now I'm there atleast 1-2 times a year.
finding out if import monster have any TE37SL's in stock and if they do I'm going to try and get my deposit back from tyrepower hawthorn and go out and buy some straight away, I'm so over waiting and being stuffed around.
After spotting you other day, I'd suggest you to buy a set in 34 GTT size and we swap cars :P
TPH gave me my deposit back no worries, you'll be right
Well it looks like I might be going from TE37SL's to bronze TE37's - which will mean I won't be able to use the centercaps I bought as they won't match..
Either way I'm about to go there now and ask for my money back and then might go out to import monster and look at the bronze ones.
Get well Hamish...
Lol people ordering today will only get delivery in march, so a while off before repo.
But we are hoping to get a couple to drive around and play with soon, hopefully will be able to take it home. If I do, you know where I'm going ;)
Keep the caps as a reminder ;)
Lol well..
After going there they assured me Saturday they will be there - Monday at the very latest.
If Tuesday comes and I don't have them ill be going straight for the bronze.
so my bros gonna take the defect cos apparently he was 'speeding a bit' down eastlink prior to it lol still reckon he should of fought it - but doesn't want to get called out for speeding
ah well /skylinedefectlyf
Edited by UNR33L
    • Put a fuel pressure gauge on it. Replace the turbos. Probably completely separate issues.
    • What copper washer do you guys use on the bleeder bolts? The existing one I have I had no idea where to find it in a local store, I did buy some online but that are only 1mm thick whereas my old one is 2mm+ thick and when I put the new washer out and squeeze the top radiator hose I can hear a bit of air but not with the old one. Does this matter? The new one doesn't leak, but the inner diameter is a bit loose whereas the old one threads on the bolt.
    • Howdy all, after being out a few weeks ago on a spirited drive in my GTR I have 2 issues that oddly have appeared at the same time. Whilst accelerating quickly through the gears all of a sudden i’ve lost power at the top of third gear (below redline around 6000rpm) for no obvious reason.    From that point onwards the car has been running rich on idle, won’t really rev under load without a ton of black smoke and the odd backfire, and dying as a pull up to a set of lights unless I keep the revs up around 1500rpm. In addition when shutting down the car that same night (I was 10 minutes from home) I noticed one of the turbos was significantly noisy on wind down when shutting off the engine. After letting the car cool down overnight it starts up fine, although once it gets to temp the revs start to creep up and down, the exhaust is darker than it should be and it also sounds like it’s running rich (fat note) I’ve put a new set of plugs in it - no change, the old plugs all seemed OK with two of them being somewhat richer/fueled up than the other 3 with 1 being borderline. I’ve smoked tested the intake system via the front of the Turbos, found a split vacuum hose going to the factory boost gauge sender, which I have since replaced.  Also found another leak on the gasket coming off the rear turbo outlet, have also replaced this. After fixing both of these leaks - still have the running rich issue. I’ve also tried another pair of AFM’s - no change here After pulling off the front turbo intake pipes, there is obvious shaft play in the front turbo, which now hisses loudly on light revvs although I can’t see why this would make the car run funny even under idle. I’m curious to know why it’s running rich before I potentially replace/rebuild turbos. The car is completely stock <50,000kms  other than an exhaust. Oil and coolant are all clear. I haven’t bothered with coil packs as it looks like they won’t be the issue due to condition of the plugs. Any help appreciated as I cry myself to sleep!
    • No probs at all. I used to love trying to dig up obscure info for those in need where possible going back 20+ years on SAU.  I did have another look and couldn't come up with any closer match. I'm leaning towards those skirts in your first pic are custom fitments, cut down/extended or from another car entirely and modded to fit an R34 sedan. I would've thought someone in Japan had them and taken a photo at some stage over the last 2 decades but there's nothing. Someone out there must know surely.
