Get well Hamish...
In other news... Aaron, can you repossess one of these and make sure no-one else bids on it at auction? :P
http://smh.drive.com.au/new-car-reviews/mercedesbenz-a45-amg-first-drive-review-20130828-2sq7w.html
  • Like 1
I'm telling you all once.... Make sure you have private health insurance. I have seen probably 25+ doctors and specialists in the last 4 days, including the head of neurosurgery. In the public system I nearly died due to not being allowed to see a neuro consult, and was left in a cubicle for 6-7 hours with no real assistance until I had a fkn seizure.
This will easily be a $10k+ hospital trip for Medibank (thank Christ I have the best cover available - commercial cover through NAB)
This is the issue we shouldn't have. The public system should be just as good as private, I just pay for it at tax time instead ffs.
I could fix the public system overnight by banning companies asking for doctor's certificates for single sick days. Bloody stupid wasting thousands of hours of doctors time filling out stupid notes so employers feel better. Spend the money on Hospitals instead.
Rant over....
Rant over....
Or stop people from going to the doctors for antibiotics when they catch a common cold, or a myriad of hypochondria.
I wasn't even aware of bulk billing until a few years ago, consequently never bothered seeing a GP for any minor shit, cause I thought it would cost me money. Someone awares me of how Medicare works, now I'm there atleast 1-2 times a year.
finding out if import monster have any TE37SL's in stock and if they do I'm going to try and get my deposit back from tyrepower hawthorn and go out and buy some straight away, I'm so over waiting and being stuffed around.
After spotting you other day, I'd suggest you to buy a set in 34 GTT size and we swap cars :P
TPH gave me my deposit back no worries, you'll be right
Well it looks like I might be going from TE37SL's to bronze TE37's - which will mean I won't be able to use the centercaps I bought as they won't match..
Either way I'm about to go there now and ask for my money back and then might go out to import monster and look at the bronze ones.
Get well Hamish...
Lol people ordering today will only get delivery in march, so a while off before repo.
But we are hoping to get a couple to drive around and play with soon, hopefully will be able to take it home. If I do, you know where I'm going ;)
Keep the caps as a reminder ;)
Lol well..
After going there they assured me Saturday they will be there - Monday at the very latest.
If Tuesday comes and I don't have them ill be going straight for the bronze.
so my bros gonna take the defect cos apparently he was 'speeding a bit' down eastlink prior to it lol still reckon he should of fought it - but doesn't want to get called out for speeding
ah well /skylinedefectlyf
Edited by UNR33L
    • Totally equivalent. Stock often goes from the comp cover because that's where the actuator is also installed and the factory needs 2" of hose to make the connection - and it comes as a pre-assembled unit. They totally have a boost reference from somewhere between the turbo and the throttle(s). Oh, jeez. Just do it in M12 then. We don't actually care that much. I would expect any such AN converter fitting to rely on an o-ring or some other seal onto a flat surface under the flange of the hex**, because bolt threads are no intended to provide a pressure seal. unlike..... pipe threads. **which also requires a suitably flat and smooth surface on the turbo's boss to provide the seal.
    • I also used NP   That’s were it’s seems to be the best place to fit it? All schematic shows also that it’s should be referenced from the turbo housing. But idk, I do see high hp cars without any connection or anything to their turbos, so I really don’t know how they connect their things
    • I do have loctite 243 and 246 and a few more models. I could drill it now in place and make new threads for m12 and order an4 - m12 coupling and fit that to the turbo. Run a braided hose to the EBC which I could get a an4 to 1/8npt
    • So M12 and sealant should be fine?    NPT ” because that’s what I had and what I could get atm.
    • Wouldn’t touch par if they gave it to me. You need to ask how much power you’re looking to make and then add about 50% to it because that’s what you’ll end up making  The factory box says no more at about 350kw or so, the upgraded synchro boxes won’t handle much over 500kw for long and at that point you’re looking at an auto or dog engagement manual,  once you’ve gone dog engagement you may as well go sequential, they cost a little bit more but it’s worth it  also while you’re at it you should upgrade the transfer case with 10 friction plates
