1) Can I book a test drive? 2) I have enquiry regarding price. 3) Can I please have more information on service history? 4) Hi, Just viewed your listing and will like to purchase it. can you advice on how long you have had the vehicle, why you are selling it, has it ever been damaged, what condition is it in, will it meet a RWC, does it have any bad habits and your final price? I will be Glad if you can send me some pictures.. Kindly get back to me as soon as possible. Awaits your response Steven
Can I please have more information on service history? Please kindly advice on the final price and the present condition...
Interested in your listing,can you send more pictures(insideespecially) to martianlabelle(at)gmail(dot)com.Regards
^ Enquiries about a car I have for sale on drive.com.au, are these scam replies or legit do you think? If scam, what blipped on your scam radars?
Car is a 2006 Alfa Romea GT Selespeed
legit.
no mention of kenya.
Well it's not my Alfa :P It's listed at 16,000 atm... would explain why it's had no bites for 3 months...
Then suddenly 3 in 2 days... from separate people...
The first one looks the most suspicious... I mean, why would his point #4 start with "4) Hi, ", sounds like a copy pasta
The broken english concerns me, though after seeing posts on drift sales, not much phases me anymore.
Sif not swap for a 33
Soooo... trying to sell daily bcoz company vehicle, but swap for unknown condition R33 so I can sell the parts for more than what Evo 8 parts go for?
profit?
dat SAU logic
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
    • Legend. I ended up finding the facebook account of the owner of the first car i sent but sadly he deactivated the account. I think you’re right in saying it’s some sort of well done custom job. Really appreciate your help anyways.
    • Totally equivalent. Stock often goes from the comp cover because that's where the actuator is also installed and the factory needs 2" of hose to make the connection - and it comes as a pre-assembled unit. They totally have a boost reference from somewhere between the turbo and the throttle(s). Oh, jeez. Just do it in M12 then. We don't actually care that much. I would expect any such AN converter fitting to rely on an o-ring or some other seal onto a flat surface under the flange of the hex**, because bolt threads are no intended to provide a pressure seal. unlike..... pipe threads. **which also requires a suitably flat and smooth surface on the turbo's boss to provide the seal.
