ahk, just thought maybe you'd read one of their brochures or something at lunch time. or receive those wonderful corporate emails about employee deals etc.
Employee deals are 21% off
Hope you guys aren't being serious
Just because you lodge a tax return doesn't mean your automatically entitled to a refund
For your average John Doe your refund is more dependant on your employer rather than the Tax Office or Accountant
got my best return in years this year. :cheers:
Edited by alr33x
Do they?
What sort of interest rates do they offer?
Normally they offer absurdly low interest rates (losing money) but then they don't discount the vehicle as much to make up for it
Just had a snoop on their website and the financing link is a dead end. they do their own insurance as well...
Anyone got some good tips for bleeding an empty clutch line?
Lol I definately need to do mine as well...
At DECA I could hardly get it into gears once it was really hot because the clutch wasn't fully disengaging... Dat crunch
When I was in 1st with my clutch pushing hard against the floor, if I revved at all it would creep forward :/
Their own = Outsourced to a supplier of credit / insurance with a slightly better rate for kickbacks?
Bleed it first, if that don't fix it, it could be the pedal position screw on the master cylinder needs adjusting.
Do they?
generally they wont negotiate one dollar on purchase price when they advertise super low interest rates, i know honda while ago had a deal on finance but it was a 50% up front payment like if you go 50% of the cars value available to you pretty sure 3% finance isnt that important.
also my mates got bmw full circle so you get a guaranteed amount for the car in 3 years or whatever but you gotta to less then a set amount of kms per year and dealer service etc. always a catch.
No mods to fit and will give the power I am shooting for
fair deal. kits you need for an e9 framed turbz don't seem to be too dear, but if you don't need them for your goals, no point. when does the stock 7 turbz start to struggle though? i thought it could make 220-230 or so...?
Empty line needs a bit work work though :(
$50 off ebay.
nah the 7 turbo is tiny, not much more than 200kw on 98, tad more on e85
    • It turns out that Setrab make a fan specifically for the oil cooler which is great and I've installed it with minimal swearing. I removed my 2x 12in push fans from the front of my aircon condenser and wired them into this. My main thermo fans kick on when I use the aircon anyway and would effectively already be working as puller fans through the condensor which is infront of the rad. The push fans (understandably) didn't really do much in the config they were previously in so now they're out. Now we're on to the "Oil fan doesn't really do much either!". Yes I'll duct it next if it does nothing in heavy use which it shouldn't. But hey, the object exists and fits great and is cool. Let me have this. The car is still in the "do my fittings leak oil now? do my wheels actually rub?" phase. I did a spirited drive on them and didn't hear or feel anything. Then I got back home and noticed there were grind marks on the inside of the rims, though I couldn't see where they were touching I got out the grinder and attacked the suspects. Note: I do not know how to use a grinder. Then I realised I had dragged my new rims across my concrete driveway before I did this drive. I didn't think I had damage at that time when I briefly looked...... but remembered this occurred after I did all the angle grinding. The grinding on the wheels in some very specific spots. It's not around the whole rim for example, which lines up with dragging it across concrete more than hitting a suspension component for even 1 full rotation. So everything is currently painted and taped up and I need to test it some more to see if it really IS rubbing, but from inside the car it doesn't feel like it is. In other news I attempted to do a before and after comparison of the heads/cam upgrade thing. Dynos lie, everything is in different measurements. Here is the data from the sandown back straight. Car go faster than before. Vroom vroom.
    • Here's my base ignition. +3 correction to redline when shooting water/meth which is always on. Looking at my old ignition table, I should be able to add 1-2 degree's next time I'm on the dyno.  Let me know your thoughts.
    • Given what I know now - same haha, but this was 12 years ago with second hand 740cc Nismo injectors in my S15 daily, I was too busy hunting elsewhere for the issue to even look at the injectors, running through some cleaner was a happy coincidence haha
    • Not a terrible idea. But if I ever had concerns that my injectors were sufficiently dirty to be causing me a problem, they would be out of the engine and onto the actual injector cleaner/testing bench.
    • Run some injector cleaner through it I had a similar issue that plagued me for months, even tried replacing the cat. If one or more injectors are blocked up the ecu sees ping so pulls timing and makes the tune rich overall, you'll see black smoke coming out of the exhaust and like me assume it's running rich but it could only be one or two cylinders  $10 bottle of injector cleaner and the next time I hit boost it pumped out a huge plume of black smoke, cleared the blockage and then ran great, if that's not the issue it's only a cheap thing to try haha
