I like this guy
If you're feeling lonely at Cabrini lemme know and I'll come in for a visit...we can talk about the rise of west coast hip hop or something.
And if the missus needs any help with anything at home or the little one, gimme a yell...I'm only a suburb away at the moment.
Hope you're out soon.
I dunno, I don't mind cats at all, they smell less, break less of your shit and kinda look after themselves...
Probably best not to ask Alvin, Jonoe, Tony, etc which they prefer...
KHIKYG
https://www.facebook.com/simon.henman/posts/10151544070386148
Please like and share my post, need to get this message out
I typed up my own.... I figured it's probably more effective to have political messages without swearing
thanks man! visit would be awesome
i'm at st vincents private though :)
Damn took a chance on ol' Cab
Off Grey St? If so, I was there today getting radiology. Due for cortisone appointment on the 17th, but I'll come past early next week or something.
/hospitalisedaustralia
b)having access to the keys/alarm/etc for "later use" :/
1. Photos of everything before you drop it off anywhere, inc tyre tread ;)
2. If you've got a powerfc or similar, drop the rev limiter to 4000rpm... When mine went in to a panel shop to get a new door / resprayed, set the limiter low and then drove it to them... Hell I could have set it lower than I did, but it was enough to stop boost coming on... or my tyres being fried like a mofo.
What would be the rough cost of re-spraying my front bar if I remove it and disassemble my self? In northern suburbs - any suggestions?
$350ish.
Carlission bodyworks in coburg.
Speak directly to zayn or huss.
Both very good friends of mine
Mohsen sent you
I only got 3.7k this year :whistling:
inb4 dezz trumps me
Can't remember what I got this year but think it was more than that. Not as much as last year though.
Got nothing on the people I know getting ~$10k...
back to LPG, my mums G6 is straight gas, and the tank takes up where the spare wheel would normally be. LPG tank must be bigger than petrol tanks (in physical size not necessarily volume), or can't be mounted as low as a fuel tank maybe..
I've tried the whole election to avoid being political, but I couldn't handle that bullshit that has happened this afternoon / evening...
How can the Communications Spokesperson not have read the Policy until the afternoon of the release, why was he not directly involved in its creation?
How can he defend the Policy, and then come back a few hours later to after the backlash to try and say that it was badly worded?
It literally said the opposite of what he spoke of on the radio... If it was just badly worded then surely he, as the Communications Spokesperson, should understand that that is not the party stance on the issues?
I just don't understand *shakes head*
unaware of anything happening in the world....
Do my 12hr work in the middle of nowhere, shut the f**k up, eat dinner, go to sleep. Repeat for 9 days straight.
bushfire near the equipment today and some massive storm coming through now
how is that going? i bought an aquamist hfs3 setup but never went through with it.
How do you make the water:meth mix?
it was going fine, its all in pieces in the garage now.
the water meth mix was easy to make, get a glass measuring container, measure out a volume of methanol and the same volume of distilled water, add to tank. if adding nitro methane to it ~125ml nitro methane to 1L of water/meth mix (should result in ~30-50hp increase, a little more nitro meth can be tollerated but not a lot, too much can just make the whole thing hard to light.)
Let me know when you're going, I'll come too!
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
    • Can I suggest you try EBC directly again and link them to as many competitor catalogues as you can to show their listing is incorrect, eg https://dba.com.au/product/front-4000-series-hd-brake-rotor-dba42304/ If you have access to an R33 GTST VIN and your VIN, you could also use a Nissan Parts lookup like Amayama to show them the part number is different between 33 GTST and 34 GTT which may get their attention
    • So i got reply from EBC and they just this site where you can clearly see those 296mm fronts on R34 GTT. I send them photos and "quotes" that 296mm are not for 34 GTT and they are too small. But it will be very hard to return them cuz nobody here knows 100% and they just copy those EBC catalogue :-D https://ebcbrakesdirect.com/automotive/nissan/skyline-r34
