I like this guy
If you're feeling lonely at Cabrini lemme know and I'll come in for a visit...we can talk about the rise of west coast hip hop or something.
And if the missus needs any help with anything at home or the little one, gimme a yell...I'm only a suburb away at the moment.
Hope you're out soon.
I dunno, I don't mind cats at all, they smell less, break less of your shit and kinda look after themselves...
Probably best not to ask Alvin, Jonoe, Tony, etc which they prefer...
KHIKYG
https://www.facebook.com/simon.henman/posts/10151544070386148
Please like and share my post, need to get this message out
I typed up my own.... I figured it's probably more effective to have political messages without swearing
thanks man! visit would be awesome
i'm at st vincents private though :)
Damn took a chance on ol' Cab
Off Grey St? If so, I was there today getting radiology. Due for cortisone appointment on the 17th, but I'll come past early next week or something.
/hospitalisedaustralia
b)having access to the keys/alarm/etc for "later use" :/
1. Photos of everything before you drop it off anywhere, inc tyre tread ;)
2. If you've got a powerfc or similar, drop the rev limiter to 4000rpm... When mine went in to a panel shop to get a new door / resprayed, set the limiter low and then drove it to them... Hell I could have set it lower than I did, but it was enough to stop boost coming on... or my tyres being fried like a mofo.
What would be the rough cost of re-spraying my front bar if I remove it and disassemble my self? In northern suburbs - any suggestions?
$350ish.
Carlission bodyworks in coburg.
Speak directly to zayn or huss.
Both very good friends of mine
Mohsen sent you
I only got 3.7k this year :whistling:
inb4 dezz trumps me
Can't remember what I got this year but think it was more than that. Not as much as last year though.
Got nothing on the people I know getting ~$10k...
back to LPG, my mums G6 is straight gas, and the tank takes up where the spare wheel would normally be. LPG tank must be bigger than petrol tanks (in physical size not necessarily volume), or can't be mounted as low as a fuel tank maybe..
I've tried the whole election to avoid being political, but I couldn't handle that bullshit that has happened this afternoon / evening...
How can the Communications Spokesperson not have read the Policy until the afternoon of the release, why was he not directly involved in its creation?
How can he defend the Policy, and then come back a few hours later to after the backlash to try and say that it was badly worded?
It literally said the opposite of what he spoke of on the radio... If it was just badly worded then surely he, as the Communications Spokesperson, should understand that that is not the party stance on the issues?
I just don't understand *shakes head*
unaware of anything happening in the world....
Do my 12hr work in the middle of nowhere, shut the f**k up, eat dinner, go to sleep. Repeat for 9 days straight.
bushfire near the equipment today and some massive storm coming through now
how is that going? i bought an aquamist hfs3 setup but never went through with it.
How do you make the water:meth mix?
it was going fine, its all in pieces in the garage now.
the water meth mix was easy to make, get a glass measuring container, measure out a volume of methanol and the same volume of distilled water, add to tank. if adding nitro methane to it ~125ml nitro methane to 1L of water/meth mix (should result in ~30-50hp increase, a little more nitro meth can be tollerated but not a lot, too much can just make the whole thing hard to light.)
Let me know when you're going, I'll come too!
    • Possibly avoid using a Cometic one unless the deck/head surface are perfectly flat. I did have a look just then and forgiving gaskets such as Tomei or Nitto don't exist for the FJ20, however the Bar-Tek or Kameari ones look good and might do the trick.
    • Because pipe threads for pipe things. M threads for bolt things. Throw some teflon sealant onto it and dust your hands off knowing you did the right thing, instead of going twice around the block to achieve a result using the wrong things. Of course, all of these solutions are ignoring the fact that the minimum thread pitch we're talking about here is 1.25mm, with the 1/4" in NPT or BPS being out around 1.4mm. You will need to know that the boss you're tapping has enough thickness for at least a few threads. That's one of the reasons that 1/8" is commonly used - because the pitch is <1mm. And why would you look to use 1/4" NPT in a BSP country anyway? Ugh.
    • Just throwing around ideas, does it need to be in the compressor cover? Why not the hot side piping?
    • 1/8NPT drill size = 8.7mm. Since the hole got messed up by me, it’s probably around 9mm.    So 1/4” NPT would be next step. A drill size of around 11mm would be preferred there which is not way of my M12 (drill 10.5mm and tap M12 threads)
    • 3 Kids are starting to hit that ages. I wanted to get them something special to learn on, put down the screens and have some fun. 4Door 2001 R34DE Black Pearl GV1 Jap Import, AU 2nd owner. Pre Work done. Suspension - Wheels Pedders SportsRyder Coilovers   Wheels TSG Spokey Boi 18'x9.5"+15 Body JASI Aero 4 door Type R Full Kit LED Conversion - Parker, Blinkers, & Reverse Exhaust Hurricane Headers 100 CPI high flow cat 2.5" Piping Cannon muffler Internal Bride low max stradia ii - front seats  Bride RO seat base and Rails (R/H) Cube short shifter LED Conversion - Interior
