PATRICK
Leesh just got defected. Window tint 1% darker than legal; window regulator faulty. Inb4 WA is next Vic.
Ahhh you think moving to Perth is your ally...you merely adopted the defect. I was born in it, molded by it. I didn't see a roadworthy until I was already a man; by then it was nothing to me but COSTLY
yea but in WA, you DO NOT have to open your bonnet when they ask.
keep it visibly legal and its all good.
Grant wears a strap on. Beware
Welcome abroad, strap on, it's wild ride in here!
That is one shiny car brah
Tradition on here is to take a shirtless pic in the reflection of your car
So we know how good your detailing is
nohomo
okay so nohomo...with the talks of strap ons...I is confused :P lol jks, thanks guys, car is dirty as fuark tho.
Also, followed by marked divvy van for a bit just before, didn't get pulled over, winning! :yes:
^Well, that's Friday for you. Drove the lancer down to thai to grab lunch... Bastards closed until 4:30. SHATTERED. At least I got a drive in :P.
Also went to vicroads... stamp duty is such a money grab.
no worries, i did scotts ones swell
Awesome. Let me know what times etc work best for you and we'll sort it out... but like I said I'm in no rush as of yet, so :P.
    • I can see between the water jacket and cyl 3 there wasn't a hard line of combustion gas. It certainly appears that the issue is coming from there. Yes, checked the tension. All at 100ft lbs where I set them 5 years ago. These blocks can crack but generally when they have been over bored. Mine is only 0.5mm oversize at 89.5mm. They break between cylinders around the 91mm mark. No sign of that with mine. My gut feeling is the head gasket lifted a while back when the studs stretched and i bandaided it by retorquing the studs. It's finally let go.
    • My Nismo 1.5 churps a bit on reverse turns when cold, but besides that feels like a stock diff.
    • Yes, but, I paid cash and I'm pretty sure the receipt was in the bin 10 minutes after I got home Note to self, keep all receipts
    • Bunnings would have just handed you your money back on that one!
    • So, version 4 intake is on its way I was looking at these a while ago but at around $200 or more it was a little pricey for something that might not work, but, I had it in my watch list, but, I got a message saying it was on special, and I had a code thingie to use, it eventually came in at $120 delivered, so BAM, BUY NOW.....LOL I'll need to have a look when it arrives but I feel it will "look" better than what I currently have, as it comes with a PCV fitting, so I will be able to get rid of the alloy pipe that goes to the throttle body with the PCV fitting  Well, that's what the voices in my head are telling me  Oh, and this happened today Yeap, it was a Trojan, and it was cheap, so I headed back to the hardware store and actually spent a little bit more on a heavy duty,  one that was actually recommended by a plumber mate, a Cyclone one with a fibreglass handle that is actually rated for clay The broken shovel will eventually be "modified" into a short handle shovel
