damn straight. you watch the arsenal game? heard they where on fire...
Don't have foxtel unfortunately so had to settle for Barcelona v Celtic on sbs. I am a gunners fan though, they are killing it
Edit: f**k Ham not the evo? :(
wiziwig is your friend. free football.
good to see arsenal and liverpool at the top. even better to see united f**king it up tho.
349kw @ E60, run out of duty
upgrade injectors
310kw @ E85
fuuuuuuuuu
What sort of mods/turbo you running?
1010159_589155074484737_1421350236_n_zps
By @gurber78, Justice for Jeremiah Meises (Jay Meezee!) The news tries to paint the motorist of the Range Rover Alexian Lien as the victim while Jeremiah Meises is the real victim who was run over by Alexian Lien whom left the scene of the accident. The video speaks for it's self. In the video Jeremiah Meises is wearing a purple tee-shirt he gets off his green motorcycle to help the guy that was first hit by the Range Rover and then he was run over by Alexian Lien who left the scene of the Intended Accident. Due to the severity of Jeremiah Meises injuries he was put in a Medically Induced Coma, he will never walk again. He is Paralyzed from the waist down with a list of severe injuries. Alexian Liem committed a Hit And Run. He did not stay at the scene and called New York City Police for help, INSTEAD HE TRIED TO GET AWAY, SO HE NEEDED TO BE STOPPED! Every single media group is running the misleading story that this was a justified act, that the biker only suffered a broken leg and that it was just a fender bender that cause all the bikers to chase down Alexian Lien. They are trying to make it seem as if Jeremiah Meises, whom will never get to walk his daughter down the isle doesn't even exist. Lets not get the story confused. First Alexian Lien hit one biker with his Range Rover. Secondly he ran over the others and then he drove away. THERE WAS A SERIOUS CRIME COMMITTED BY ALEXIAN LIEN
Poor Range Rover driver..
Still on the side of the range rover driver.
Sympathy's for Jeremiah who seems to be an innocent in all this
But what would you do in that situation? For me I would have done the same thing
Seems as though they have charged the biker who did the brake check making him responsible for the whole incident
More details here
http://jalopnik.com/biker-at-start-of-terrifying-range-rover-attack-arreste-1433776499?utm_campaign=socialflow_jalopnik_facebook&utm_source=jalopnik_facebook&utm_medium=socialflow
Footage of before the incident:
http://www.liveleak.com/view?i=3cd_1380579664
Yeaaaa buddy! Shocks finally came from Germany, got em for under 900 including shipping. Was worth the wait in the end! Can finally lower my car without it being more boat-like than it currently is on shot KYB's :woot:
you must be tiny? how do you reach the pedals?
Everything major on a RB28 (neo)
Just didn't hold boost. Was oddly laggy on first tune, now it's better response wise but won't hold boost.
Its a hypergear turbo, a one off that even Stao can't quite remember what is in it.
He's offered me two others to test/swap, one bigger and one smaller. I have unrealistic expectations :P
+1 for Bilsteins, I am really happy with mine, but compared to stock as my only viewpoint you'd hope to be for the price
Wow Rb 2.8 Neo
Don't see stroked Neo's everyday
Good ol hypergear turbos
I got a ss2 at the moment thats a restriction. Im thinking early next year ill just go a Garret 3582, ext gate
Get E85
    • Put a fuel pressure gauge on it. Replace the turbos. Probably completely separate issues.
    • What copper washer do you guys use on the bleeder bolts? The existing one I have I had no idea where to find it in a local store, I did buy some online but that are only 1mm thick whereas my old one is 2mm+ thick and when I put the new washer out and squeeze the top radiator hose I can hear a bit of air but not with the old one. Does this matter? The new one doesn't leak, but the inner diameter is a bit loose whereas the old one threads on the bolt.
    • Howdy all, after being out a few weeks ago on a spirited drive in my GTR I have 2 issues that oddly have appeared at the same time. Whilst accelerating quickly through the gears all of a sudden i’ve lost power at the top of third gear (below redline around 6000rpm) for no obvious reason.    From that point onwards the car has been running rich on idle, won’t really rev under load without a ton of black smoke and the odd backfire, and dying as a pull up to a set of lights unless I keep the revs up around 1500rpm. In addition when shutting down the car that same night (I was 10 minutes from home) I noticed one of the turbos was significantly noisy on wind down when shutting off the engine. After letting the car cool down overnight it starts up fine, although once it gets to temp the revs start to creep up and down, the exhaust is darker than it should be and it also sounds like it’s running rich (fat note) I’ve put a new set of plugs in it - no change, the old plugs all seemed OK with two of them being somewhat richer/fueled up than the other 3 with 1 being borderline. I’ve smoked tested the intake system via the front of the Turbos, found a split vacuum hose going to the factory boost gauge sender, which I have since replaced.  Also found another leak on the gasket coming off the rear turbo outlet, have also replaced this. After fixing both of these leaks - still have the running rich issue. I’ve also tried another pair of AFM’s - no change here After pulling off the front turbo intake pipes, there is obvious shaft play in the front turbo, which now hisses loudly on light revvs although I can’t see why this would make the car run funny even under idle. I’m curious to know why it’s running rich before I potentially replace/rebuild turbos. The car is completely stock <50,000kms  other than an exhaust. Oil and coolant are all clear. I haven’t bothered with coil packs as it looks like they won’t be the issue due to condition of the plugs. Any help appreciated as I cry myself to sleep!
    • No probs at all. I used to love trying to dig up obscure info for those in need where possible going back 20+ years on SAU.  I did have another look and couldn't come up with any closer match. I'm leaning towards those skirts in your first pic are custom fitments, cut down/extended or from another car entirely and modded to fit an R34 sedan. I would've thought someone in Japan had them and taken a photo at some stage over the last 2 decades but there's nothing. Someone out there must know surely.
