I honestly wouldn't know what to do. Everyone says I would've done this "oh I would've beat that muddafwakka" but when you're in the actual situation and panicking, you wouldn't know what to do
Assume foetal position.
Fart loudly.
Nah, run over a guy and leave him paralyzed cos who cares right?
even the cops said he had a broken leg only... kinda hard to know who's lying and cbf finding truth
dont try to understand their rational, they're stupid bike riders acting like tuff guys cos they're in a group. even if he did hit one of them, get his plate and let him go
Great post you flog. I'd love to see you stay calm and composed and pull out your notepad to write down the plates of the guy that just drove his 2tonne car over your mates, in the process of a hit and run.
What sort of mods/turbo you running?
Still on the side of the range rover driver.
Sympathy's for Jeremiah who seems to be an innocent in all this
But what would you do in that situation? For me I would have done the same thing
Seems as though they have charged the biker who did the brake check making him responsible for the whole incident
More details here
http://jalopnik.com/biker-at-start-of-terrifying-range-rover-attack-arreste-1433776499?utm_campaign=socialflow_jalopnik_facebook&utm_source=jalopnik_facebook&utm_medium=socialflow
Footage of before the incident:
http://www.liveleak.com/view?i=3cd_1380579664
Personally I wouldn't have attempted a hit and run, potentially killing more people in the process, but that's just me.
top bloke deserved it. If you stupid enough to use yourself as a human barrier against a mobile 2.5 tonnes, you deserve to not have legs.
Fire up dezzman
I don't own a road bike and can fairly safely say I wouldn't have run someone over. Maybe a love tap, sure. But from the very little I can be bothered finding out about this incident, there's no real reason to maim a motherf**ker, even if he is being a flog
    • Oh, also, forgot to add these photos I believe.
    • Thought i'd update on this. I was able to get in contact with Craig Lieberman and later on Darryl Alison (owner of Kaizo Industries). Darryl was able to help me verify that my car was in fact one of theirs and is helping me find more info on mine !
