I honestly wouldn't know what to do. Everyone says I would've done this "oh I would've beat that muddafwakka" but when you're in the actual situation and panicking, you wouldn't know what to do
Assume foetal position.
Fart loudly.
Nah, run over a guy and leave him paralyzed cos who cares right?
even the cops said he had a broken leg only... kinda hard to know who's lying and cbf finding truth
dont try to understand their rational, they're stupid bike riders acting like tuff guys cos they're in a group. even if he did hit one of them, get his plate and let him go
Great post you flog. I'd love to see you stay calm and composed and pull out your notepad to write down the plates of the guy that just drove his 2tonne car over your mates, in the process of a hit and run.
What sort of mods/turbo you running?
Still on the side of the range rover driver.
Sympathy's for Jeremiah who seems to be an innocent in all this
But what would you do in that situation? For me I would have done the same thing
Seems as though they have charged the biker who did the brake check making him responsible for the whole incident
More details here
http://jalopnik.com/biker-at-start-of-terrifying-range-rover-attack-arreste-1433776499?utm_campaign=socialflow_jalopnik_facebook&utm_source=jalopnik_facebook&utm_medium=socialflow
Footage of before the incident:
http://www.liveleak.com/view?i=3cd_1380579664
Personally I wouldn't have attempted a hit and run, potentially killing more people in the process, but that's just me.
top bloke deserved it. If you stupid enough to use yourself as a human barrier against a mobile 2.5 tonnes, you deserve to not have legs.
Fire up dezzman
I don't own a road bike and can fairly safely say I wouldn't have run someone over. Maybe a love tap, sure. But from the very little I can be bothered finding out about this incident, there's no real reason to maim a motherf**ker, even if he is being a flog
    • Put a fuel pressure gauge on it. Replace the turbos. Probably completely separate issues.
    • What copper washer do you guys use on the bleeder bolts? The existing one I have I had no idea where to find it in a local store, I did buy some online but that are only 1mm thick whereas my old one is 2mm+ thick and when I put the new washer out and squeeze the top radiator hose I can hear a bit of air but not with the old one. Does this matter? The new one doesn't leak, but the inner diameter is a bit loose whereas the old one threads on the bolt.
    • Howdy all, after being out a few weeks ago on a spirited drive in my GTR I have 2 issues that oddly have appeared at the same time. Whilst accelerating quickly through the gears all of a sudden i’ve lost power at the top of third gear (below redline around 6000rpm) for no obvious reason.    From that point onwards the car has been running rich on idle, won’t really rev under load without a ton of black smoke and the odd backfire, and dying as a pull up to a set of lights unless I keep the revs up around 1500rpm. In addition when shutting down the car that same night (I was 10 minutes from home) I noticed one of the turbos was significantly noisy on wind down when shutting off the engine. After letting the car cool down overnight it starts up fine, although once it gets to temp the revs start to creep up and down, the exhaust is darker than it should be and it also sounds like it’s running rich (fat note) I’ve put a new set of plugs in it - no change, the old plugs all seemed OK with two of them being somewhat richer/fueled up than the other 3 with 1 being borderline. I’ve smoked tested the intake system via the front of the Turbos, found a split vacuum hose going to the factory boost gauge sender, which I have since replaced.  Also found another leak on the gasket coming off the rear turbo outlet, have also replaced this. After fixing both of these leaks - still have the running rich issue. I’ve also tried another pair of AFM’s - no change here After pulling off the front turbo intake pipes, there is obvious shaft play in the front turbo, which now hisses loudly on light revvs although I can’t see why this would make the car run funny even under idle. I’m curious to know why it’s running rich before I potentially replace/rebuild turbos. The car is completely stock <50,000kms  other than an exhaust. Oil and coolant are all clear. I haven’t bothered with coil packs as it looks like they won’t be the issue due to condition of the plugs. Any help appreciated as I cry myself to sleep!
    • No probs at all. I used to love trying to dig up obscure info for those in need where possible going back 20+ years on SAU.  I did have another look and couldn't come up with any closer match. I'm leaning towards those skirts in your first pic are custom fitments, cut down/extended or from another car entirely and modded to fit an R34 sedan. I would've thought someone in Japan had them and taken a photo at some stage over the last 2 decades but there's nothing. Someone out there must know surely.
