Only reason I would ever go to frankston would be to shoot junkies
you mean sip cocktails while your mandingo shoots junkies?
frankston is reasonable, alot worst places.
unless your out on the piss there......
Maybe top gear can do a test where they get a few different four wheel drives to run over motorbikes and measure their 0-100...my money is still on the SRT Cherokee.
f**k this shitty Melbourne weather
Birds, I'm due in for another wax I think :P I'll probably give it a crack myself this time hehe :)
lol fk waxing your cruise liner by hand again
    • Oh, also, forgot to add these photos I believe.
    • Thought i'd update on this. I was able to get in contact with Craig Lieberman and later on Darryl Alison (owner of Kaizo Industries). Darryl was able to help me verify that my car was in fact one of theirs and is helping me find more info on mine !
