A good parma wins hands down imo, or even a pie and coke for that matter...
hard to find a decent pie in vic. most are shirty by lunch time.
NZ however, f**king gourmet shit in every town. had soooo many pies. got to try venison, lamb, mutton, scallop... mrs mac can eat a dick
Lold at this.
Etihad will be fine for your 10 year old commodore brah
it could be a 20 year old skyline, but i still wouldnt want it nicked! :woot:
etihad it is. anyoneelse going to bring me the horizon tonight? or are they too mainstream for you hipsters?
also that $50 5 course menu from the vue de monde chef at clayton bowls club was in the age yesterday and it's pretty much booked out till the end of time
sounds like the Frangga RSL...its so busy they built another room for all the people that dont book....but the food aint as good
i catch train to work every day and am at spencer st by 7 (it's free if you touch off before 7)
pussy
pussy...she must be nice to get you up that early every morning..
Because Hampton Park bogan. :P
nice try......but you still aint frankston
franga ol' g for lyf son!
do not have time have to be there at 7...... plus public transport is for tramps, asians, and hipsters.
and asian hipsters.
nah, i caught train for f1. wont be doing it again ever.
I will be sure to avoid the white English man when he aboards the train / tram etc...
:laugh:
    • So.... the K&N air box thingo was too big, ended up gifting it to a mate, well, by gifting it he actually supplied food and beer at the pub,  which was nice, as it will not sit on a shelf in the garage for the next 10 years I did trim up some of the existing stuff to neaten it all up and gave it some wrinkle paint, unfortunately it currently has a used and abused mish mash of different types of hose clamps, 4 big fat T bolt type (shit), and a few normal clamps of vairing sizes and brands, but..... only until the 6 constant tension black worm clamps that I ordered from EFI solutions turn up next week Currently the current hose clamps are triggering me hard, LOL Is this the final version, probably not, I really want just 2 silicone pieces, a straight bit of silicone from the filter to the MAF is easy and will happen as soon as I head into Just Jap tomorrow, the problematic part is a 30° silicone bend from the MAF to the TB that I can connect the engine breather from the head, I found that there are bulk head fittings for boat bilge pumps that should work, but until I can get a 30° silicone bend the alloy pipe, and the 11ty thousand hose clamps, are there for the foreseeable future 4 hose clamps are golden, 6 are grudgingly acceptable, the 8 currently holding it all together is just taking the piss    I've also ordered 60 more retaining wall blocks for the front yard, I mis-gonculated the height that was required to get above the base of the Photinia's (red robin's) that are the hedge behind the front fence, currently it is 2 blocks high, and about 1/2 a block short, so going 3 blocks high will be above the base of the red robin's, and allow some room for mulch
    • It is the stock air box with the panel filter. Everything else is stock except the exhaust at this point, as I also went back to the cleaned 270cc injectors. I will check the RPM when the IACV is unplugged and report back.
    • As MBS suggested if this is happening when the engine is cold you're going to want to remove the intake air regulator and verify resistance + that the shutter is physically opening and closing. At -20C should be fully open, 20C half open, over 60C fully closed. At 20C should be 70-80 ohms. For AAC valve testing using a Consult cable see if you can raise and lower the idle by commanding more or less AAC duty cycle. Hopefully it's pretty linear as well, shouldn't be like 30% AAC valve is barely idling and 40% is 1500 rpm.
    • Bloody apprentices! 🙄
    • Not sure yet.  Was considering speedtek because it was rated to 800hp, but when I did some research about him I don't think I will go for that🤣 So maybe giken gear set, but I'm afraid it won't be strong enough🙄
