this page makes me angry. some people who dont work in offices occasionally rely on office people to do their jobs so people out of office can do their job.
stop spreading the anti-motivation *crack whip*
So you mean people like me, who spends more time at customer sites than in our office???
he is the new guy tho so I don;t want him answering the phone when I call in with a issue, I was the pissed off lifer who does not want to work but knows that obscure bit of info that I need!
fresh graduates...we don't even trust them to make the coffee..
Yeah, did work at Kmart footz but transferred to Werribee and now doing full time eng work placement on top as it's unpaid placement.
Walked around heaps at Kmart, something like over 20k steps within an 8hour shift compare to like 50steps a day in the office if anything....
Also did some labouring when not at kmart so definitely not used to office work!
Heck, I fell asleep yesterday morning and almost fell off my chair... :unsure: (Had no work to do so starred at a monitor)
Yo how do people keep up with more than 1 forum at a time? I kinda have to drift between them all I can't go to all forums at once it's too much LOL
Do it during business hours bro
Pro tip: I use google chrome for my personal surfing and internet explorer for work related stuff so when you need to show someone something there isn't a million tabs of pron :yes:
Edited by UNR33L
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
