i found clearance was getting quite tight with the following setup.
17x9 +22 with 8mm spacers
inner clearance, brake clearance, guard clearance or homo clearance?
also what tyres?
also what tyres?
guard to tire, has to run the 8mm spacer to clear the brakes too with that wheel design. and once you take the 8mm spacer into account they are +14 offset.
235/45/17
drove around trying to find a BP with 98 today.. couldnt find one =/
son... you just booked yourself in for a self-righteous ethanol rant when birds gets here...
235/45/17
so i need to find an extra 8mm clearance less say 2mm for the extra stretch on the tyres... so roughly 6mm...
easy
easy
not so much for the front the rears are where you need to check/get some extra space, possibly do the bolt mod
I must be the only person who's not has that many fuel issues... Filled up the day after the fuel panic bs began, and twice since then... 2 servo's have been temporarily out of 98, but the next one down the road have been fine...
I was just bathing in the irony that the concern of most with regard to using E85 is availability, when I heard you say my name!
finding right tyres/wheels... evo problems
finding right fuel... skyline problems
limited choice wheels and good fuel economy... pulsar benefits
yeah, i'm sure finding wheels and not requiring as much fuel is definitely easier, but how hard was it telling your dad you're gay?
  • Like 1
depends on the wheel design though, what was it?
importing a car and having it sit at the compliance shop for 2 months due to department of transport.... majesta problems
LOL!
bad: psych assignment due tomorrow; have not started.
good: found it's only worth 20%, not 30% as i had previously thought.
this is getting the way of my pokemon playing, grrr :@
Had same issue yesterday when I was in the area before work.
Ended up filling at shell on Blackburn and Reynolds rd.
    • I'm with you here. It's either loom has an issue, OR, injectors are not functioning properly. It could even be they're just constantly dribbling, hence the wet, but not firing.
    • Depending on how long the car sat it is very possible for injectors to be stuck open or closed, I'd get them cleaned and flow tested. Other than that, obviously when the loom changes and the car doesn't start any more....the loom is suspect so some tracing / comparing may be required
    • Harness is for a s1 Rb25det, and it is engine and lower harness.  the old harness had broken off plugs and was in very rough condition/exposed wires and splices etc. it is not able to be put back on the car, I could visually inspect to see if they had rewired any pins on the ecu plug. The fuel pump definitly isn’t turning off it’s an external pump and very loud you can hear it. Will look at the other harness tonight, am also going to pull the fuel rail and watch the injectors spray, will update here with what I find. Pretty sure at this point it has to be something to do with injectors because car will fire up on starting fluid and cas is clicking the Injectors. Fuel pressure is steady 43psi
    • Check the injectors flow evenly, and are actually flowing what you and the ECU think they should be flowing. If it's starting up on starter fluid, you have a fuel issue. Is it possible under cranking your fuel pump is turning off?   The harness you replaced, is that the whole engine harness? Do yourself a test, and drop the old harness on and plug it into the Z32 ECU. It's possible they've wired things different. From memory S1 to S2 is different in RB25 and you may have a wrong loom
