Tyres do harden in the weather and tyres on cars are through heat cycles that help to keep them from hardening. The latter part may be total shit, but it made sense when I made it up.
Regardless, distributors note year of manufacture and sell older stock for cheap for a reason.
Yeah was thinking that too but got to consider tyres aren't made yesterday. Would be coming via boat from china which is months and by the time you buy them, they have been sitting for ages anyways.
Could argue a tyre going through heat cycles would cause more wear as it's expanding and contracting.
hmmm.... it's just that I've got an old set of tyres in the backyard out in the open, used to be in the shed but needed that space.
So two sets of wheels with tyres on both sets, and I want to swap them around.
Would they charge the usual or double because they're taking off and putting on twice?
I've got a pair of jack stands if you want to borrow.
Haha saw that today. Classic
Slow and annoying.
Bought a 34 GTT, saving up for another gtr or o/s trip.
You really need to just buy a car and stick to it
Hmmmm, what are AD08's worth in 265/35/18? Any good place to get them from, fitted, in South East or Bayside or even Dandenongish area?
Cheapest AD08's would be about 380-400 fitted
The newer AD08R's are $450-$500 fitted
O/S
play with cars later
I've done both before, think I might do both, can always sell the 34.
The o/s will be short burst not 3+ months like last time.
It's wishful thinking really, blame it on my attention span and genes (father switched cars a lot, grandfather does every year before retiring).
I mean to actually swap the tyres from set 1, put them on set 2, and the tyres on set 2 to put on set 1.
Just jack up the car at each corner and swap each wheel one at a time. Will take 10 minutes tops...better than a car place doing it. Have a wheel brace if you need it.
I think young Jonoe meant taking tyres out from wheels set 1 to wheels set 2 and vice versa.
Costs me $5 a corner to have tyres swapped, $10 if I want them to get rid of the old tyres, seeing as you're keeping both sets though that's not gonna matter.
The benefits of living out in sticks, low overheads.
keep putting off doing research/pricing into semi's.... will wait for my RSRs to disintegrate. Probably wont go RE002s again either cause they pricey for what you get, but then again I dont really do enough kms for wear and tear to be a problem (other than -3.5 camber wear)
cool 7 degrees and wet on Mt Dandenong. yay
this dude snuck up on me earlier. abdomen was bigger than my thumb
Abz where are you?
11degrees in melb ATM but being in the office and judging by the current status of my nipples, it's roughly 23.5 degrees.
hahaha lol'ed.
meant body temp with this constant fever. :/
    • Thanks for doing that Duncan! Makes you a good person in my books. We don't get kangaroos or wombats here. But we have bats and it's similar. AFAIK it's often the mums with a baby attached that get hit because they drop lower when starting from a tree. If you hit an animal, check on it. https://www.ifaw.org/au/resources/wildlife-rescue-app An app to get the closest wildlife rescue contact.
    • My dream is also to have a proper hoist, but I don't think it will ever happen. My quickjack is probably as close as I'll ever get, it really is very good though.
    • Yeah we keep on in the dailies, it is pretty poor how many animals get hit and the driver leaves without checking....have saved a couple of little ones over the years. Bit of a gruesome job though, pouches generally need to be cut open because they are so tight and often the joey doesn't realise mum is gone so they are still locked onto the teat. I checked the modules in front of the DS wheel where an oil cooler should go.... There is the radar unit - that can go for race use) One of the 2 HX water pumps, the silver cylinder. That needs to be kept but might be able to be relocated But the bad news, the big computer mounted vertically in front of the wheel (blocking any potential air exit) is the electric steering computer. That is required until/unless i do a hydraulic steering conversion, and in CAD based modern car design it is not like I can just pop a big unit like that somewhere else (plus the loom would be too short anywhere else too). So, the passenger side is OK to clear out (just use a smaller washer reservoir, potentially elsewhere), but the DS no beuno
    • Well, all the best with the new camry It was interesting to hear about the UK process, it is generally a lot more streamlined here with a shipping agent looking after all the import side (noting the exact final price can still be a surprise.....) and I've used a few different brokers on the japan (or US) side, and never had any trouble with any of them....luck of the draw I guess. You mentioned you didn't get the auction sheet (understandable since you bought it from a dealer, not auction), but I always try and get hold of that because they are pretty thorough. I've imported 2x R grade vehicles over the years and both were fine, repairs in Japan are pretty thorough compared to here in Oz.
    • BTW I measured the jack I have, it is 70mm at the saddle but you only have about 700 until it returns to 150mm high at the cylinder so it is good but no magic bullet.
