If the damage is too a roof, I'd speak to the other neighbours about trying to get in contact with them... before it rains... Or things will get a lot worse...
The garden shed is a little more compact, but the roof looks ok, otherwise I would have called the SES.
Just glad I don't have to pay
hey nick,
the XXR 527's in 18x9.75+20 that you had what did you need to fit them when you had the tien progressive springs?
i'm thinking im gonna go same same... $800 you cant go wrong lol
also i'm thinking 245/40/18
sup
is it just me or does every evo 8 have a different shade rear bar?
ive looked at so many and i think in all of them, the rear bar is a different tinge/shade compared to the rear quater panels
surely not all of them have had touch up / spray work ?
sup
Can't say I've noticed a different shade on my bro's gunmetal grey 8MR
Then again I could be wrong
hey nick,
Are XXR Wheels any good?
Or they are just another Rota cheap ass fake wheel brand?
Only 2 AD08R's in 285/30/18 left in Aus..
Need 4 ;(
Lol you're chasing it a few days after World Time Attack.... Mistake :P
Wait a few weeks, they'll bring in a heap of them because of how many cars were repping them over the weekend.
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
