Will do Martin!
You're in Yarraville if I remember correctly?
Why you party poop and no deca?
Tried a water bottle cap and it's just a bit small, milk cap seems too big. :-/
Newport so close enough.
no seat in car so no racing, parts just not coming in in time.
still coming up, just not driving anymore.
I might have a set of S-chasis rails in my garage...
Swear i've seen the original image on here before but this popped up on my newsfeed....dem photoshop skills.
Yeah that's my picture
Must like taking pics off my FB page. I think Steve runs the FB page, his a nice guy though
Bit of a gay photoshop to be honest
  • Like 1
So driving to work this morning for the first time since working on the car all long weekend.... Of course, popped a cooler pipe.
Turbo -> Intercooler... the one underneath everything... had to remove the airbok etc etc etc and get dirty in my work clothes :(
Luckily I stand by carrying all my tools with me for a few days after any mods, just in case :)
Billowing black smoke and strugging to keep idle without revving, turned into a servo after stalling twice.
Happy Hump Day :| 30 minutes late to work on the week where I'm only working for 16 hours, and I need to take some time off on Thursday afternoon so I can get a taxi to go and pick it up from the retune before driving straight to Shepp so I can do Winton on Friday.
#lastminutemods
If only you went MAP sensor like all the cool kids. You could have driven to work with no boost like a boss.
On the plus side scotty... I hit a little bit of boost just fine the other afternoon... but as soon as rpm and boost went up... it all went to crap and I'm assuming it leaned out (didn't pop a hose, but it blew dark grey smoke and lost power for the 0.5 seconds it was happening)
Retune is booked for tomorrow, and it drives around fine off boost.
Your pipe certainly sounds different to stock when the BOV air enters it... when I let off the gas (from about 2psi) it does its normal shhhhh and then about half a second later (when the air gets back to the intake pipe?) it goes kerchewww. Can't wait to hear it at full song :)
Hopefully no dramas on the Dyno, since I'm leaving for Shepp Thursday evening :/
Ooooo also, New Koyorad and Nismo Thermostat and 1.3Bar Cap = 67c driving temp, 69c max temp over an hour of driving, comes up to temp fast, and stays there rock solid. But yeah, haven't boosted yet.
Also haven't gotten the temperatures high enough for the new Tomei oil cooler w/ thermostat to open up yet.
Who would stock an adaptor which would screw into a hole which is 18mm/1.5mm thread and be able to accept a smaller sensor... unsure of the actual size... about 12mm across perhaps? Will get exact measurements at lunch time. What kind of shops stock fitting like that?
SIMON, you should've replaced the clamps while it's all apart.
One of these days you'll break a clamp in middle of nowhere, like it did for me one time.
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
