I wonder if VicRoads actually ever moderates the declared value of people handing in transfer forms.
I know plenty of "friends" who under-value their cars by thousands on those forms, and for good reason, those stamp duty charges are ludicrous!
Simple answer. Yes when they get audited, no if not
was raining outside, good time to sand down headlights for glassylite :P
Not a good time for dat nano sealant though...
Give it the full 24 hours without moisture; I let it rain lightly on the nano after a couple hours last time and now have small spots all over headlights that I can't remove until I sand it again.
happy 23k.
yeah parked it in the shed and did the rest in there, rain stopped so can start to take measures for tanks in the boot without getting wet now
Anyone into man powered bikes?
I want to get my first one. Been told a good mountain bike to start on would be a jamis x3 trail.
$600 give or take.
Need to get fit. Advice?
Alvin can build you one with his bare hands
$600 give or take.
Get a hybrid, half mountain / half road.
Easier to ride on bike trails and can do the occasional gravel.
You are not going bush bashing and won't be on the roads as you hate cyclists. You will be sticking to bike trails.
Get an entry level bike for $300, upgrade when you know what you really want and suits you.
    • Thanks for doing that Duncan! Makes you a good person in my books. We don't get kangaroos or wombats here. But we have bats and it's similar. AFAIK it's often the mums with a baby attached that get hit because they drop lower when starting from a tree. If you hit an animal, check on it. https://www.ifaw.org/au/resources/wildlife-rescue-app An app to get the closest wildlife rescue contact.
    • My dream is also to have a proper hoist, but I don't think it will ever happen. My quickjack is probably as close as I'll ever get, it really is very good though.
    • Yeah we keep on in the dailies, it is pretty poor how many animals get hit and the driver leaves without checking....have saved a couple of little ones over the years. Bit of a gruesome job though, pouches generally need to be cut open because they are so tight and often the joey doesn't realise mum is gone so they are still locked onto the teat. I checked the modules in front of the DS wheel where an oil cooler should go.... There is the radar unit - that can go for race use) One of the 2 HX water pumps, the silver cylinder. That needs to be kept but might be able to be relocated But the bad news, the big computer mounted vertically in front of the wheel (blocking any potential air exit) is the electric steering computer. That is required until/unless i do a hydraulic steering conversion, and in CAD based modern car design it is not like I can just pop a big unit like that somewhere else (plus the loom would be too short anywhere else too). So, the passenger side is OK to clear out (just use a smaller washer reservoir, potentially elsewhere), but the DS no beuno
    • Well, all the best with the new camry It was interesting to hear about the UK process, it is generally a lot more streamlined here with a shipping agent looking after all the import side (noting the exact final price can still be a surprise.....) and I've used a few different brokers on the japan (or US) side, and never had any trouble with any of them....luck of the draw I guess. You mentioned you didn't get the auction sheet (understandable since you bought it from a dealer, not auction), but I always try and get hold of that because they are pretty thorough. I've imported 2x R grade vehicles over the years and both were fine, repairs in Japan are pretty thorough compared to here in Oz.
    • BTW I measured the jack I have, it is 70mm at the saddle but you only have about 700 until it returns to 150mm high at the cylinder so it is good but no magic bullet.
