Are you serious about turboing the micra?
yup. not for a while tho.....
Ceramic wheel 32 GTR turbo? Naice.
Lets bolt it on Platts. :)
they are gtr, not sure if 32 or 33 tho....
and not yet dude.... gotta rego and rwc the pig first!
have to find a way to deal with fuel pressure, but the car will run 5psi with out anything else.... doesnt need injectors ecu anything. just zaust and manifold.
hahahahaha.
Like the mech will pop the bonnet for rwc. lol.
hahahah. if you gotta dodgy one then im down.
if not, it can wait. knowing you, youll wanna put all sorts of fancy shit on it, flux capacitors and the like.
I could think of a few mods...
What can you knock off from work? :P
hahahahaha. i got a few tasty things in here at the mo, but they are leaving in an hour. no chance of knocking em off!
When he sees Paul he will check that it's not an explosive
you saying i look like taliban my friend.....
At least then it might do 88mph
hmmmm still might be a push.
They're 33R.snails
still ceramic tho?
Yup still ceramic, I guess you could always chuck an ebay N1 rebuild kit through the broken one if you wanna shove more boots in :P
thats a good point!
but i doubt ill need any more power than stock mate-torque steer is a killer.
and the only lsd avail, is a nismo one at about 4 grand.
For me, fishing is not about catching fish, it's about hanging out with my mates in the sunshine with an esky full of beer and talking s%#t
Though... This is the last fish I actually caught... Was a 14kg Mahi Mahi... Gave it to the place I was staying at and it was cooked in a traditional oven underground and fed everyone. notbad.jpg
428392_10151358304916746_2082240263_n.jp
http://upload.wikimedia.org/wikipedia/commons/c/cf/MahiMahi-bull.jpg
mahi is 9kgs max. defs not a 14kg. just sayin.
    • So could it be assumed it has been installed intentionally with potentially a power FC boost controller kit?
    • Had my rig on Matt's dyno at PITS the other day. After a few years between tunes I added a few sensors and swapped intercoolers. Result. 553hp at 26psi. Not bad for an FJ20 that was built in 2007. The problem.. It filled the overflow bottle on hard runs which leads me to believe the head gasket isn't sealing. I have a coolant pressure sensor which was reading cap pressure at 22psi and occasionally overrunning to 23/24 psi on deceleration after a pull. It was not spiking. It has arp2000 head studs and a cometic gasket. As its been 18 years in service, I pulled the engine out and head off. Everything looks good but we obviously have an issue. Where I'm at.. Years ago I had the same issue, I checked the stud tension and they were all over the place. Some at 60 to 70 and some up near 90. I nipped them all to 100ft lbs and this stopped the water push until now. I believe this compromised the gasket back then. What do I do? 2 options are..  1) I bought arp 625+s, which I could put in with a new gasket. Thinking Kameari this time, reassemble and try again. 2) strip the block, get fire rings machined in with copper gasket and try that. I do not want to push it more than 28 to 30psi. I think the turbo will be out by then anyway. (G30-770). My other concern is the long term ability of a copper head gasket. Are they streetable for years? I feel like a new gasket with the new studs will probably suffice, but I don't know. Any thoughts welcome and advice on copper gaskets and fire rings. Thanks!
    • I'm a fan of the JZX110, and the Aristo. Big cruiser cars, and with the factory cars, super comfortable and feel like you're driving an armchair! And the JZ motors are a pretty nice engine too, especially with some basic mods.   The import process, and the need to be able to trust people, and the fact there's so many scammers around is what ever puts me off wanting to go through that ordeal!
    • I don't care for these at all, but at least the underside looks straight and not rusty. A good basis for a long life. Many cars from Japan have been lifted with forklifts and f**ked almost irrepairably.
    • Yes, but it's not dumb or dodgy. You can build a perfectly good boost controller from a pressure reg, a relief valve (looks same same as a reg if all from Norgren or SMC, for example) and a check valve. I ran one for years. Only superceded with  EBC because I could get one for cheaps and wanted finer control.   THis mod is certainly not a sketchy boost mod, provided the boost is kept below the "spin to death" threshold of the turbos.
