Restriction is the turbo exhaust housing I believe...
3" JJR Stainless Bellmouth Dump/Front pipe
3" Highflow cat, which isn't even a 100 cell, I think its 200 or 300?
and it was pretty much a straight though system with the Kaki R (2 mufflers)
You gonna come to the ethanol side anytime soon? Keeps the backside nice and clean :)
Nein... I do too many km's to be even more inconvenienced by needing to be picky about which servo I can go to... Would need to swap turbo to get the most out of the extra power as well...
if i ever plan on going to Vietnam i would do something similar.
Was actually planning on going to Panama last year to do a 9 day kayaking trip through the carribean. i pussied out though.
Got some pics
Accommodation at this beach was $10 a night for a cabin and $25 for a pimped out room
  • Like 1
I only gained 20rwkw up top because of my small turbo, but in some parts of the midrange I gained 40rwkw. Plenty of Uniteds around; there's one 5 mins from where we live (near Alvin) and a 24 hour one off Eastlink in Scoresby. So worth it!
Come on Scotty gimme backup...
2835 KGO!
hmmm vietnam...been there 7 times now...hated it more and more everytime
that said I'm a special case for my trips as there for work.
So booking flights for my next holiday in next few days.
Thailand - krai
Philippines - boracay
Fiji - denaru isalnd.
hard to decide
You just can't tell some people.
If Simon wants to be different and run Dinofuel who are we to single him out? He will come around one day, probably just after his ring lands go. :P
just too mut f**king around to go etOH,
so i'll stick with dino fuel.
most importantly without a proper jerb, no budget here.
If you've already got a tuned 98 with safe supporting mods, it's as simple as a tune. I don't even have a wideband. For the extra $500 or whatever your tuner charges, worth it to have an ethanol tune stored on a laptop should you want extra power for a given time period. I keep laptop in my car...if I don't have an ethanol station in sight, just go to a place with 98 and switch to 98 tune. Simples.
Thailand - krai
hard to decide
What do you hate about it? I think it's amazing someone could live like an absolute king in Hanoi. $450/week apartment in Melbourne is about $300 a month there. Get a small passive income and you're set for life. My only complaint was no chocolate milk, and no milk in general. Damn lactose intolerant Asians.
no tune yet. but nistune is on the cards.
can i swap tunes with nistune?
the general attitute of the locals.
DUe to working there for significant periods of time I got to know some.
they sit around with beers on a Friday discussing who F%$ded over the tourist the most as a joke.
only place I have been robbed
and then the hygiene, middle of town, watched lady carry baby into the street, hold it above the gutter so it could "go potty" then bring it back inside.
and the gourmet cooking:
So yes can live cheap, but a life I don;t want, where for less money I could be in Laos that was much better, or a little more gets you thailand.
my objective is to never go back.
Laos
    • Apologies for the long post, but needed somewhere to lay out the entire timeline of events and actions taken:   I've got an 89 GTR with a R34 RB in it. It's been running great all year, driven probably 500KM in the last month. It's not my daily driver, just a weekend fun car.    Build info: R34 RB26 - HKS 2.7 stroker kit, HKS adjustable cam gears, HKS turbo upgrades, Trust intercooler, R34 factory DENSO 440cc injectors, JUN chipped/tuned R32 ECU. All of this work was performed in Japan back in 2019.    Thursday 10/2/25 - It's a nice day and decided I'll drive it to work, I start it up in the garage and I notice it took a few extra cranks and sounded a bit funny. I figure maybe it was just because it was a pretty chilly morning. I pull it out into the driveway to warm up a bit before leaving. As I leave the driveway, it feels very off and sounds like a misfire. I pull it back in the garage to deal with after work and take the daily to work. I was able to diagnose it as a cylinder 5 misfire with the old spark plug test (unplugging each plug until a sound change with the engine running). I take off the whole ignition system, ignitor, plugs, spark. *Important note, it is still on the R32 ignition system with the separate ignitor system. I test each system with a multi-meter and nothing presents as a smoking gun. I put it all back together and it starts up no issue. I go ahead and order the PRP R35 ignition conversion kit. It should arrive today (10/13/25)   Friday 10/3/25 - Another nice day, car starts up great and drives great all day. Very pleased that everything seems to be OK   Sunday 10/5/25 - Decided I'll take it to play some golf, load up and drive to the course about 25 minutes away. Drives wonderful the whole way there, I pull in the parking lot and the engine completely comes to a stop. I do not recall if it sputtered at all, but just remember all of the sudden the engine was off. I roll it into a parking spot, try to crank it back on and nothing.  It'll crank and crank and not even try to start. End up getting it towed back to my house and push it up into the garage.    Items I have checked: Fuel in the tank Fuel Pump relay Fuel pump fuse  Spark Plugs & gap Coil packs Ignitor    I know the cylinders are getting fuel as the plugs smell like fuel after a start attempt. I tried spraying starter fluid into the manifold and cranking and not even a sputter.    I decided to do the live CAS test (removing the the CAS, ignition on and spinning the CAS stalk to see if the injectors pulse and spark is active). All of the injectors were pulsing and I have spark at the plug. The half-moon end of the CAS did seem very loose, I'm not sure how much play is supposed to be there, but it was more than I expected. There was no in/out play of the shaft, just the tip end that is pinned on had quite a bit of play.    CAS Play video   When I put the CAS back in, I stupidly did not re-time the engine. I know I need to do that tonight, however, I do not think it will start given it seemingly was not the issue. My plan is to do the PRP R35 coil kit and retime the engine at the same time.    I plan on ordering the Haltech Nexus Plug-in ECU once they are available again, but ideally would like to get this sorted before firing the parts cannon at it and potentially adding more variables.    Anything glaring that I am missing here, I'm a bit at a loss?
    • Get it on a dyno. Get something logging Consult. Run it up and find out what is causing it.
    • Looking for a plenum for rb25 de+t neo  Not looking to push much power maybe 300kw at the wheels, is there much difference in flow for Freddy “Greddy style” compared to original Greddy or options like Proflow or Otaku garage?    I won’t be porting the de Neo head for now as I think it’ll be fine 280-300rwkw but appreciate the help and any experiences anyone has between them and any advice. Thanks  Looking at this plenum for now below
    • engine wise almost no mods: stock ecu Greddy front mount intercooler Greddy forward facing intake w R33 TB stock fuel system, stock injectors, rail etc. Kakimoto racing hyper 3 inch exhaust system Apexi intake filter New NGK –R BCPRES (.8 gap) plugs
    • Nice one @Pac - looks like a fair few 1600's there!
