#@Miguelone
lol sorry again, what's the part number for s1 reo bar and headlight brackets?
and what's the part numbers for s2 reo bar and headlight brackets?
S1 Reo 62030-AA030
S1 headlight bracket RH 26040-AA000
S1 headlight bracket RH 26090-AA000-
S1 side piece RH 62244-AA000
S1 side piece LH 62245-AA000
S1 Grille bracket 62240-AA000
S2 Reo 62030-AB000
S2 headlight bracket RH 26040-AB000
S2 headlight bracket RH 26090-AB000
S2 side piece RH 62244-AB000
S2 side piece LH 62245-AB000
S2 Grille Bracket 62240-AB000
I want to go white water rafting. Is kayaking hard?
Already booked Sri Lanka for January and Fiji for feb lol I'm feeling a bit like martini
white water rafting is pretty frantic. quick do this, do that. against the current essentially. but at the end f the day, the torrent of water is propelling you.
sea kayaking is much more leisurely and you don't really get wet. but it's in the sea, so little waves, bit of against the current etc
8:28am: Arrive at Vicroads Burwood
8:30am: Doors open
8:31am: Receive Ticket
8:31am: Ticket Called
8:33am: In inspection bay
8:35am: Roll stick under the car, hits it, but good enough anyway
8:36am: Stamp Stamp "I'll take care of this and mail it off, have a great day mate"
8:40am: All smiles and on my way to work
S1 Reo 62030-AA030
S2 Reo 62030-AB000
cant seem to find the s1 reo on amayama, but the headlight brackets seem to be cheap enough.
    • So either way it is gearbox out and look what is wrong?  I know about the input shaft bearing. Even before swap/new clutch the it sounded exactly like this: So is that inout shaft bearing or the other was installed backwards?  And can some please tell me the part number for that input shaft bearing? The gearbox is small box from R34 N/A and number is FS5W71C. Thank you
    • I am yet to see anyone ever regret a quaife or helical. ...other than drifting/skidpan duties. I kind of want to upgrade my factory helical with a Quaife (but really it's not ultimately that different, and is a MASSIVE UNDERTAKING), that's how good the hype is about them, that I want to try them 'just to see'
    • D2 and Ksport are essentially the same thing and basically just generic Taiwanese manufacture. Better than ChinaBay crap, but... not top shelf. Öhlins have got to be some of the best dampers around, so likely to be a good option. It's going to get to the point though where I suggest you buy from Oz. We have at least 2x excellent options here. If I were you though, I'd be talking to KW about doing something for the R33. There's bugger all difference between that and the 32. In GTR land, anyway.
    • KW only offers a set for the R32 GTR. Popular options are D2 racing, Ksport or Öhlins. I have a D2 Racing coilover set, though I don't know for sure which one.
    • Well, the good news is you have more than one very good option for new coilovers in and around your country. Worth the drive over to KW to talk about GTR stuff.
