VF GTS is about 100k on road as far as I remember, pretty sure they come with AP racing brakes too?? (even though they probably say HSV on them)
My mates boss has one reckons its decent for a new stock car
Even still brah I don't think you'll get one for that they command a premium
especially 1 week before race wars
I'd hate to have 100k to spend on a car
Suck it up princess
f**king lol
  • Like 2
So those playing at home, got the iPhone 5s.
Ported over my iphone 4 apps, photos and all in a couple of minutes.
No messing around, simple is best.
Bought a Nexus 5... Booted it up for the first time, "Would you like to install the apps which are currently installed on your Galaxy Nexus?" Yes plz. 5 minutes later everything is perfect.
Agreed, Simple is best.
  • Like 1
N5 > IP5
That will be all. How are you liking it so far, Simon? I played with my mates the other day, quite smooth. I appreciate the slightly extra screen real estate over my N4 as well.
N5 > IP5
Tbqh it doesn't feel like I have a new phone. It's all the same as my 4s.
Barely notice the larger screen. Finger print unlock is fancy though.
I'm loving the nexus 5, it's not too big like lots of people have been saying... Considering I've come from a 4.65" Galaxy Nexus to the 5" Nexus 5 its not a huge jump in size...
Battery life is awesome, Push Email + Facebook notification + a few 10-15min phone calls + Whatsapp and SMS all day long, and I was coming home from an 8 hour day (plus an hour of driving each way) with 75%+ battery life
It's light, but still feels really solid and well made. If you're going to get one, I'd recommend the black. I got the white and now I can't use it in the garage like I'm used to :P My GNex I'd pick up with grease COVERED hands and zero fks given, just give it a wipe on my shirt when I was done... It's a bit trickier to clean black off the white back cover.
I'm honestly not sure how Apple manage to make so many people splooge over the most minor incremental upgrades... People rushing out to buy a $1000+ outright phone, sure its got a slightly faster processor... but all the apps are designed to function on the lowest common denominator (which is the lowest phone running the current OS, iP4S) so you don't really feel the power boost anyway... I'd love to buy a beer for the guys in their marketing department, they sure as hell know what they're doing :)
Edit: Speaking of keyboards... I've just installed a new one called Fleksy, really intuitive and easy to use (after the day or so of un/learning curve). Just wish it had some swype like functions as well. but other than that, its really accurate and smooth as butter.
C63 must be due for new model starting to look dated IMO
Aaron could confirm?
need aaron's insider information! :P
that's true. they black edition coupes are still hawt, though!
sounds good :)
my n4 isn't even a year old tbh, although given the price point i could upgrade to n5 for not much, i'll probably wait it out until the next gen of phones/nexus.
i use swype these days, good stuff. only thing i hate is the stupid lack of return key in the messaging app... but that is google's fault :P (i wonder if it's any different in hangouts... not sure i want to use hangouts)
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
